Help return fuel line
Harv1994
Marylsnd
2002 Jetta
I have a 2002 Jetta tdi. I bought it had the timing kit done . Cat was clogged had it hollowed out. Was driving it for two weeks and the injector return line started leaking . Ordered new lines put them on now the return line cap keeps shooting off every time the car is running . Any ideas ?
chz17
Boston, Mass.
2002 jetta TDI GL 5spd, 2004 jetta TDI PD
The injectors fuel return line pressure should not blowing the little cap off. Inspection the line to the injection pump have any blockage.
Harv1994
Marylsnd
2002 Jetta
New cap for it. Blew air though the return line that goes back to the fuel tank and the t on top of the filter . Ran good no leaks for a day or so then just blew the cap again started pissing fuel let it sit for about 20 min then fired it back up no leaks. Do you think the #1 injector could be gummed up ?
P2B
Toronto & Muskoka, Canada
Wrong return line. Check the one from injectors to injection pump.
