tanner
- Joined
- Jan 31, 2013
- Location
- Alabama
- TDI
- 2005.5 BRM 5-Speed, 2013 Golf TDI 6-Speed, 2011 Golf TDI 6-Speed
VCDS PDF
Here’s my first run with Ross-Tech VCDS. I did this with the car turned off and ignition on. Should I test again with engine running?
1. I know I have a bad fan, or at least I thought it was a bad fan. It says movement restricted I’ll take another look tonight as it says intermittent is there a chance it kicks on and off?
Ignore the EGR and Particulate filter.
2. ABS, RPM, TPMS faults. This is one I want to clear soon as my dash looks like a Christmas tree. Any help on what steps I should take on fixing?
Any help will be beneficial. Let me know what I may need to do. Rather run test again with engine running or what not.
Cars been sitting a while and I just replaced timing belt using DG kit, installed Sigma6, aluminum skid, new tires, etc. I would like to get this car running like as good as I can. I’ve been driving it and it’s doing great just tired of the fault codes.
