Hi all,
I did find my issue was the starter. I purchased a new one on E Bay, best for the $$$ and New!
Replacing the starter was not that hard and is done from the top.
Remove the cover on the battery
Remove
Remove the air cleaner cover
On the front part of the air cleaner,
Removed large snap ring from the intake
Use a little WD-40 or oil on the rubber mounts holding the air cleaner and battery box together it will help separating them. Remove the bolts from the battery tray remove the ground from the starter or not the start of the job Audi to the party grounds remove the plug, holding this, has the cable on to the solenoid .
The two bolts are 16 mm and or 8 mm hex lift the hoses on the top one wiggle and get the right size socket for the lower one. Don’t forget to remove the wire deposit wire. Remove the starter. I’ve been to check mine got nothing.
The front part of the air cleaner on snaps the top, and then the box below it that has the round portion in it.
Good luck, I did this a while ago and the description may be a little rough but it should be a good over view.
Vic
