Help! Need Advice Interpreting VAG-COM Data
Alchemy
N/A
None thanks to dieselgate
Wow, after being absent from the forums for over a year, I find myself coming back seeking advice. Here is the situation. I own a 2000 Jetta TDI and over the last few months I have noticed a cyclic surging during acceleration, especially at WOT, and the cruise control cannot keep up at highway speeds. So, being a geek engineer I decided to buy the VAG-COM software and OBD connector. After performing a scan, the data came back looking like the following...
http://home.wi.rr.com/stevemetz/Jetta.jpg
What do you think? Wastegate controller? MAP sensor? My original thought was the MAF sensor, but I don't see that as being the case because the boost is so erratic.
Other info... 72k miles, 5 speed, Delvac-1 every 5k miles.
Thanks!
Steve Metz (alchemy)
Alchemy
N/A
The link above has been repaired. Sorry for the error.
jaydhall
Aurora Colorado
2012 Passat SE, 1999 NB, 1999.5 Jetta GLS, 2004 Jetta
Looks like the MAF to me. To make sure, unplug the MAF and then look at the same graph (with new data of course). I bet the MAP smoothes out. If not, I will have to rethink!
Alchemy
N/A
Here are the results with the MAF disconnected. Certainly looks like that is the problem, but would like your opinions.
http://home.wi.rr.com/stevemetz/Jetta2.jpg
My bigger gripe is that VW wants $350 for a new one!!!
Any other sources out there??
Thanks,
Steve
VelvetFoot
Sand Lake, NY
NB, 2000, Yellow
How does it run with the maf sensor disconnected? Better? Almost as good as new without that pulsing? If so, I would say maf.
If not, here is another idea:
Did you make sure your intake is clean, like esp. the snow screen? Perhaps the snow screen is so clogged that the oscillations are caused by the bypass door opening. The air flow levels, even with pulsing, is definately lower than requested.
Aren't you getting any fault codes?
A dying maf, USUALLY I THINK, just sort of fades away, along with the power, rather than this pulsing thing.
jaydhall
Aurora Colorado
Yes, it is your MAF. No question. Look up Danix in the for sale section. He sells them cheaper. (I have bought two from him and he is a good person to deal with!)
Other than that, www.vwparts.com.
Alchemy
N/A
The acceleration smoothed out, but was not nearly as strong. This is due to the injection quantity backing way off with the MAF disconnected. Snow screen cleaned completely and bypass door checked for function with no issues. Have not yet dropped the intercooler lines to see how dirty they are.
Alchemy
N/A
My brother-in-law stopped over with his 2000 NB TDI and we did a quick 5 minute swap of the MAF's. Definitely the MAF and have placed an order with Danix. Please may he have one in stock!
Thanks for all of your advice and help!
Steve
danix
Raleigh, NC
None now. Former: 2011 335d, 2010 Jetta TDI, 2003 Jetta TDI Wagon. 99.5 Jetta TDI, 98 NB TDI, 3 different black 96 Passat TDI wagons.
