TDI_Dad
I have a 2010 Jetta TDI with 105K miles.
This morning the bulb indicator light lit up with 9 "check" messages in the MFD.
Check right back up light
Check left front side light
Check number plate license plate lighting
check front light hi beam
check third brake light
check your left brake light
check rear left turn signal
check front right turn signal
check front right low beam
The lights were actually not working. When engaging the turn signal I would get the short blinking of the turn signal, indicating a bad turn signal bulb.
I checked every fuse in the car, not just the ones associated with the light system, and did not find any blown fuses.
I stopped by a local parts store and replaced the front right headlight bulb. When I turned the lights on the headlight worked. I was not looking at the other lights at that moment. I turned the car off and on again. This time the front light was not working again. I checked the other lights mentioned above and they were not working.
I drove home and began searching the web for anyone having a similar issue. I did not find any information related to an issue like mine. Within an hour of being home I went back out to my car to better document the issue and all the lights is working fine and there are no error messages in the MFD.
There have been only two issues with this car. The first was about three months ago I had to replace the RCV valve in the A/C compressor. About two months ago I replaced the battery. Otherwise, the car has been great. The mechanic who did the RVC replacement did take the compressor out of the car to do the work. I don't think there would be anything related between A/C and the lights, but thought I would give as much information as possible about the car.
I have made some VAGCOM modifications. Turned off the DRLs, turned off the seat belt chime, remote windows, Bluetooth phone-book in the MFD. Note that these mods were made three years ago, so i doubt they have any relation to the current issue with the lights.
Any help is greatly appreciated.
Thank you in advance.
