4th4
This question's been beaten to death I know, but I've been crawling these forums for about a month now and so many of the threads on this topic get derailed or hijacked so I figured I'd just phrase my own topic in the TDI 101.
I have a 2005.1 Jetta Wagon BEW with 205k miles.
The PO did an "egr delete" and egr cooler bypass. He did leave the egr in place however.
My understanding is he didn't want to remove it in case he moved to a smog inspection state (I do not live in an inspection-State so this isn't a concern for me). and the cooler pipe kept cracking on him so he installed a bypass kit.
No other mods that I'm aware of and the car runs great.
My mileage isn't horrible (approx 500 miles per tank of diesel)
PO always used whatever oil is recommended for the BEW cam-wear issue, which I will continue to use as well. I have a quart of it I just forgot the name.
I'm told a "tune" will help smooth the boost curve out a little bit (i.e. help it run better).
Will it also help with economy?
Not looking to turn this into a sports car, just want to increase my range without getting weird about driving habits (don't want to turn into a hypermiler)
The car is plenty zoomy which I like. Not interested in upgrading my clutch right now either.
Malone stage 1 or stage 1.5? What will that get me?
I'm hearing reports of folks getting 60+ MPG's with the right mods. Is it realistic to think a "tune" will increase mileage?
Thank you!
Thank you!
