It's been hard for me to see what to do with part load boost. I'm running 11mm with Titan 764 nozzles (240?). So my fueling, though it says 51mg, is actually more. But I did trim down the requested boost a bit below 20mg, and no smoke!
I figured that with EGR, let's say maf 300- the boost will be higher because the turbo has to push air in against the EGR gasses that are already pressurized due to EMP (however low they are).
Remove that EGR, and now you need practically no boost to do even 420 mg! So, it seems to only really need the boost past mid range...
I used to have a VNT15 stock turbo, tuned to 18.5 psi, no problems at all. Spikes were crazy actually when I changed nozzles but didn't get retuned, lol.
N75 info:
According to vag com and easy view in vagedcsuite:
20 means max vacuum to actuator, closed vanes
80 means min vacuum to actuator open vanes
But the confusion is that the actual values are inverse.. So some mapping programs may say 80 when they mean 20. How you can tell is that at higher rpm/ higher fueling, the stock map numbers go towards opening the vanes.
Make sure you set the actuator to crack at 3in Hg and be fully at the stop around 19in Hg. Or you can do what I prefer, set the low boost position to have a little bit of preload pushing on the stop. That way I have more spring force against the flow of exhaust on the vanes.
To set the n75 map, you take vag com, set up ONLY group 011 for logging (as it cant do too many fields - slows down sample time), and run WOT 3rd gear from 2200 or so up to redline. Look at the CSV file in excel or open office. You will see where the boost matched requested and the n75 duty cycle at RPM. Those values would go into your n75 map for whatever fueling you run (I assume 51mg?). For the values that don't match close at all... I would disregard those numbers because the ecu does its own PID adjustments to get target boost. You pretty much will see something like for example
2500 70%
2700 70.2%
3000 70.6%
3250 71%
3500 71.3%
and so on. Those n75 values are what you put in your table.
Make sure you smooth it out. If you are running less than 51, lets say 46 now, then make sure the next column is a bit higher. Lets say you need 71 at 3500 rpm, and are using 46mg. Then set up 40 column to have 70.5 and 51 to have 71.5 so that in between (where 46 is ) gets the 71 you wanted!
For me, I was getting undershoot, because I purposely adjusted the vanes to be conservative like I explained above about preload. So I had numbers in vag com that were lower than what was in my n75 map. After adjusting that, I am spot on perfect!
