thanks David, i now you have alot of experience with this sort of thing. i will contact you when i get the motor fit. its a 2002 alh w/37,000kms. would i have to install the cluster somewhere in the car? the motor comes with a1 motor mounts, gbox, stage 3 upsolute kit but no chip.12mm pump head and .216 nozzles,Peloquin O2J LSD,ecu, cluster 2 keys (primary and valet) complete interior and engine harness (w/spare engine harness) pedal cluster,Saab IC, transmission w/shifter box and cables, 100mm drive axles
