jollyGreenGiant
Actually they put out OK light the problem really occurs when one leaves them on.
They get all melty and the glass goes klink...
So is there anything else special about that bolt, other then the head? Could someone just slot the head, remove the bolt and replace it with something conventional?runonbeer said:That ain't no hex head boy!
required tool
try a search for "pump leak fix" or the like. its been done and documented before.
Figured it out (I measured the three flat sides of the bolt head), it's a 7mm 1/4" drive socket with three sides rounded. I went to the pawn shop and bought several 7mm sockets for trial and error and used a flexable shaft grinder with a small stone to modify three sides of the socket. Got it right the first time and fits like OEM. I'll have to post pictures. Total cost was $.50 and 3 minutes of my time.Ray_G said:I have also seen something about just driving a 1/4 inch socket
Ray
Got the scribing thing, but the Vag Com element to fine tune it and check for exact alignment is what I am unclear of.whitedog said:Marvin, in case I wasn't clear before, just take a scribe and scribe through that yellow paint and line up the marks when done. Then check and do the tap-tap.
Nice!P2B said:Here ya go....
Simon
I was pretty sure it should be. I think he just posted that to be sure that he was on the right track for checking.rdkern said:IQ should be check hot - so it probably does matter.
Fully warm, that would be a high setting.
No, the plunger/piston/pump head assembly will fall back into the same position when tightened back up thus no correction needed.Do I need to check/set the iq after doing the ip head seal? I just set iq to 3.6 w/ hammer mod last week when I changed the top and middle seals...
