dremd
- Joined
- May 31, 2007
- Location
- South Louisiana
- TDI
- 06 sprinter. 03 jetta wagon premium with 6 speed ALH swap, 14 JSW
To me the noise sounds a lot like a tire with a bad "feathering" but I thought it best to take a video.
http://youtu.be/tAakJlj4SJ8
Noise attributes.
No noticeable change with the following
Engine on/ off
Braking some/ none/ quite a bit
Turning left / right
In my mind that narrows it to the following
wheel bearings which should change with turning
CV joints that should change with acceleration / turning
Transmission output shafts that are way hard for me to deal with.
Please prove that thought process wrong.
What I've done in effort to fix it.
Check CV boots none are torn.
Change tires (which were almost in wear bars).
Drive around trying to figure out what is wrong.
I'll be honest, could be just about anything, I've done so much stuff to the car that chances are I did something dumb.
Noise attributes.
Engine on/ off
