slam
Need a little help from the forums this week. I've driving cross-country trailing a motorcycle and I've hit a bit of a snag.
Battery light started flickering this morning at 65 mph+. At first it would stop flickering if I released the accelerator, but in an hour it was solid at 65 mph+, and by evening it's solid at all speeds.
Pulled into an Autozone, checked my battery, it's fine. Bought a multimeter and I get 12.5V when off, 12.4V when running, both checked at the battery. I also checked power from the alternator positive terminal to the alternator body and it shows 12.4V.
Alternator belt was literally done just before this trip. Brand new, it doesn't appear to be slipping. Tension is good.
I can pull the alternator and test it at Autozone but I have limited tools on the road.
Two questions:
Have I ruled everything out but the alternator itself?
And if I do replace to the alternator, do I need to replace it with a 120A or will the 90A do? The smaller one is in stock; the larger will take two days to arrive leaving me stranded in Michigan City, MI, on my way to California.
Thanks folks,
Scott
Two questions:
Thanks folks,
Scott
