Heavy white smoke, CEL, VCDS Autoscan
benIV
Southeast NC
2003 PG 5m Jetta GL Sedan, 2003 RS 5m Jetta GLS Wagon (Golf Variant)
Questions I'm asking:
1. Why am I having all this white smoke all of the sudden
a. Is it just a glow plug/harness or is it something like the head gasket/nozzles, etc.?
2. Did I do the autoscan right?
I appreciate your time and any advice/opinions I can get.
There was a little white smoke on startups but not a big problem. went away for a week. Started up the car to go for a drive and the smoke billowed out non stop as long as i was idling. it didn't go away like normal. started to drive, every increase in the accelerator caused more smoke to come out. CEL came on shortly after. Ran VCDS for the first time :) yay. Autoscan results are as follows:
Wednesday,12,July,2017,21:29:30:00816
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 17.1.3.0 HEX-V2 CB: 0.4336.4
Data version: 20170320 DS267.7
www.Ross-Tech.com
VIN: WVWSP61J83W580243 License Plate:
Mileage: 371370km-230758mi Repair Order:
Chassis Type: 1J (9M - VW Jetta IV (1998 > 2014))
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
75 76
VIN: WVWSP61J83W580243 Mileage: 371370km-230758miles
Address 01: Engine Labels: 038-906-012-AGR.lbl
Part No: 038 906 012 GN
Component: 1,9l R4 EDC G440SG 4308
Coding: 00002
Shop #: WSC 01266
VCID: 629EA334CD5F82175BD-4B3C
WVWSP61J83W580243 VWZ7Z0C7298552
1 Fault Found:
17056 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 - 35-10 - Electrical Fault - Intermittent
Readiness: 1 1 0 0 1
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0004097
Shop #: WSC 01266 785 00200
VCID: 3330167027255B9FE0B-5184
No fault code found.
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 F
Component: 03 AIRBAG VW61 0202 0003
Coding: 12339
Shop #: WSC 01266
VCID: 2708F220E6FD273F4C3-5160
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 906 L
Component: KOMBI+WEGFAHRSP VDO V11
Coding: 04432
Shop #: WSC 00000
VCID: 313C1C78D839698F927-5160
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 01266
VCID: 70BAD97C13B32087DD9-5160
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 8A Komfortgerát HLO 0003
Coding: 00259
Shop #: WSC 01266
VCID: 37282260365DB7BFDC3-4B1E
Subsystem 1 - Part No: 1C1959801A
Component: 8A Tõrsteuer.FS KLO 0009
Subsystem 2 - Part No: 1C1959802A
Component: 8A Tõrsteuer.BF KLO 0009
Subsystem 3 - Part No: 1C0959811A
Component: 8A Tõrsteuer.HL KLO 0009
Subsystem 4 - Part No: 1C0959812A
Component: 8A Tõrsteuer.HR KLO 0009
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
49-10 - No Communications - Intermittent
Address 56: Radio Labels: 3B7-035-1xx-56.lbl
Part No: 3B7 035 180 E
Component: Radio NP2 0008
Coding: 00031
Shop #: WSC 01266
VCID: 221EE3348DDFC2171BD-5160
End----------(Elapsed Time: 07:54, VBatt start/end: 14.1V/14.3V)-----------
I really expected a lot more on the autoscan. Am I doing something wrong? Engine off/on key on/off? I had the engine running because i was told that was what i needed to do. Correct me if i'm wrong.
wonneber
Monroe, NY, USA
I would think auto scan should have gone through everything.
I don't have VCDS so I can't answer 100% for it. (I use VAD on an old Palm Pilot)
The 00532 - Supply Voltage B+
Could be a bad connection s/a a bad ground.
You need the wiring diagram to get the pins to test for power and ground.
Do you have the Bentley manual?
I was starting to think an aftermarket radio but no codes were found and it looks like valid info.
I would first check for bad grounds from the battery to the body and to the engine.
Test with the car running, lights on AC on
Measure from the negative post of the battery to a ground point in the body, then from the negative post of the battery to body of the alternator.
I would not want to see more then a few tenths of a volt.
The ground wire under the battery tray has been mentioned many times.
I prefer an amperage test on the glow plugs.
They should all be close to the same reading (15 or so amps iIrc)
A resistance test could be used and if the plug is open it would show no continuity.
The harness has been known to have bad connections, I could not get mine to clamp tight.
wonneber
Monroe, NY, USA
Should have mentioned with 230K miles the injectors might need checking.
I think I read they need a refresh at 150K and I do get some white smoke when I start at 260K.
I think fix the glow plug issue first, might be easier and relatively inexpensive.
Test first before throwing parts in the car.
It can be expensive playing a guessing game.
UhOh
PNW
2000 & 2003 Golf GLS (2005 Mercedes E320 CDI)
Can you provide some history/background on this car?
Does it start up (cold) OK?
I don't think GPs should play much of a role in this as ambient temps are, I"m assuming, above the threshold (41 degrees).
If you don't know when the fuel filter was last changed then I'd consider doing that, along with running Diesel Purge.
Since you have VCDS you should be able to get a better insight into what is really happening. I'd suggest taking a look at injector balance, for starters; and in general I'd look to do some performance logging (Malone Tuning has some good instructions on what/how to do). Would hope that your timing didn't "slip".
BobnOH
not-a-mechanic
central Ohio
New Beetle 2003 manual
Your autoscan looks right. The only engine issue is the glow plug, intermittent, doubt that's giving you those symptoms.
So focus on things not monitored by the ECU, there are plenty. Wore out injectors, bad compression, basic time, loose piping, leaks, etc. (not the easy answer I know)
benIV
Southeast NC
Thanks. I spoke with growler about it (since it's Knurren) He believes it may be some slightly worn valve guides perhaps and that letting it sit longer will cause larger plumes of smoke.
It starts up fine and runs fine other than the smoke. It actually did stop smoking after I ran it down the road a little further and didn't smoke the rest of the day.
Ambient temperatures are in the mid-upper 90's so I'm well above the 41, lol.
I'm gonna check the plugs because of the one code and replace the harness.
Are valve guides replaceable? repairable? I'll be looking through some other threads and stuff to figure it out, and of course, with any help you all have :)
UhOh
PNW
What's your oil consumption like?
One of my cars has a bit of an appetite for oil yet it exhibits little smoke when starting up (it's a manual trans car with an 11mm IP, so heavier fueling- I'd expect it to smoke the most at a cold start): my wife's car (now approaching 200k miles) probably smokes more and it goes through a qt of oil in about 8k miles.
I'd heard some of the top guns here say that leaky valve guides weren't all that prevalent.
aja8888
Texas..RETIRED 12/31/17
Out of TDI's
You have to pull the head to replace valve guides. Usually, the valve stems, which ride inside the guides, are worn too so they must be checked for wear with a micrometer.
In essence, if you have worn guides and valve stems, what's usually done is a head refurbishment. If the oil loss through the guides is not much, you can probably live with it for a long time.
Back in the old days with Chevy heads, we used to install valve guide seals which was a quick fix for worn parts. With VW heads, maybe this is not an option. I have not rebuilt a VW head so I can't confirm what can be done, seal wise.
