Racerxr
manual trans 2015 golf tdi se got a few weeks ago wrecked all i had to do was replace bumper cover and radiators main aux and ac condenser and support got it all done vacuum filled coolant. fired it up test drove 5-10 miles everything was great! next morning battery was dead put new battery in as soon as i hook the cables up it sparks, the heater support pump? turns on and runs til the battery is dead. cold car no key in ignition
I'm assuming its the heater support pump from what i can tell. aux pump is between radiator and engine the pump that is on is between engine and firewall on passenger side
this is my first VW and first car with electric cooling pumps so what do I check is there a relay could really use some help here thanks guys
