Ok I've done a fair amount of searching for topics that went into specifics about retrofitting heated seats to cars that did not come with them. I've been down this road before but it was on my old Subaru Impreza I bought a Corrado so I could strip the heated seats harness and elements since I was framilar with the wiring. From the searching I've found a few links to old topics with broken links. I'll tell you what I have:
Seats:
The switches and plugs:
This information from the Vortex listed by Boraguy01:
[ QUOTE ]
its actually pretty easy....ill give u a simplified version
parts needed
1 X
1J0-963-563 (drivers side switch)
1 X
1J0-963-564 (pass side switch
2 X
8L0-971-972 (these are the "switch-connector" that have 6 terminals. They plug into both the pass and driver switches) 2 X $3.68 = $7.36
2 X
1J0-937-731 (green plugs that plug into the seats themselves)
1 x
000 979 407 6 mm Repair wire - $5.40
3 x
000 979 227 2.5 mm Repair wire - $2.35 x 3 = $7.05
4 X
000 979 135 1 mm Repair wire - $1.75 x 4 = $7.00
directions
1) on the "switch-connector" there are 6 connectors (ill name them as they are numbered on the "switch-connector")
terminal 1 powers switch backlight when lights are on
terminal 2 + connection (goes to seat plug).
It plugs into seat green plug terminal 4
terminal 3 heat sensor connection (goes to seat plug)
It plugs into green seat plug terminal 2
terminal 4 + connection (goes to fuse 44, use 7.5amp fuse if only 1 seat is being wired or use a 15amp fuse if you are doing both seats......on the other end of the fuse--->goes to unswitched power (connection 30 under the relay plate)
terminal 5 goes to (any fuse spot u can find empty and use) then to switched power (connection 75x under the relay plate
terminal 6 Ground (you can use the ground terminal for the intruments thats right below the steering wheel)
------green seat plugs------
on the green seat plugs there are 6 connections, only 4 are used....2 of which i already stated above, the 2 other are ground which are in terminal 1 & 3....again u can ground this to anything.
here is a picture of the relayplate power sources u will be getting power from
***i got this from
john@abella.net, thanks***
[/ QUOTE ]
I can handle the running of wires and doing all of this. But my goal is to not use scotchLock wire taps and Boraguy01 has got me started on the path of not using these connectors so
My question/s:
1) For the illumination where are people tapping in and what should I use?
2) The instructions listed above tell me where to get constant power from but seems a little vague on the fuse area. Do I need any dealer repair wires to activate this?
3) For the switched power wire It tells me where to go but not what wire I'll need.
I plan to take pics of the specific wire connections as they go in the fuse panal so people can in the future have a little more straight forward how to.
Any help is appreciated. Thanks. Frank /images/graemlins/smile.gif
