We need someone to check their coolant circuit after a dpf delete with super low miles ( less then 20k), and is up near 80s+
Im curious if extreme heat of the egr system is causing issues....
Sent from my s-off'ed m7 with CM11
I've been deleted since 30000 and mine was completely clogged at 70000. I think the damage was already done though. I went 2 winters with very poor heat so I was probably closer to 30000 when it was happening. Ive gone to green organic acid coolant and installed a coolant filter and Im issue free at 95000
