The heater core is open to the coolant flow at all times.After reading all of the posts in this thread, I figured I'd check the heat output of my Passat on the way to work (20 mile drive, 86F out). Opened the windows and turned the heat to HIGH. Let it run for at least five minutes. Thinking maybe it's possible that during the summer months when the heat is not needed that the antifreeze in the heater core is stagnant and coagulating?
VeeDubTDI, is there a physical shutoff valve to the heater core when the heat is off? Maybe we need to 'exercise' the heater every couple weeks if that is the case. I don't have the in-depth knowledge of the components to come to that conclusion.
I know that there have been issues with antifreeze mixtures such as DexCool that congeal/coagulate under certain circumstances. I'm curious if the antifreeze in our VW's is prone to blocking the passages in the heater core when not being circulated.
Thoughts?
Yo...VeeDubtdi guy...are you paying attention? Didn't someone send you a clogged heater core? Did you ever cut it open? I think you posted photos, comparing the core to an earlier model, but not an actual side-by-side comparing "a" and "b" versions.tdiatlast: It is based on the "b" suffix, plus when I spoke to VW of A yesterday they did not deny the redesign.
I don't understand how the heater core is part of the emissions system. Please explain.An update on mine... I took it in to a dealer in Folsom CA last week. They diagnosed it and said that it was the heater core and wasn't covered under any warranties. I pointed out to him that California warranties the EGR system for 7/70,000 and that since this was part of that system it would logically be under warranty. ( I have 55,000 miles ) He requested a "courtesy consideration" from VWoA and they covered it 100% so it seems like it's just a crap shoot as to whether they cover them or not. If they say no at first I would definitely keep pushing and calling VWoA and respectfully asking them to step up to the plate for you. I'm currently asking them to just take the car back and give me my money so we'll see how that goes...
The EGR cooing circuit. The heater core is part of that circuit apparently. In most cases in warmer climates the lack of heat isn't noticeable at first. But the clogged heater core triggers a CEL that gives a code related to the EGR system. The only way to fix this fault in the EGR system is to replace the heater core.I don't understand how the heater core is part of the emissions system. Please explain.
I'm not saying I'm necessarily totally correct. What I'm saying is that this problem causes a fault code that refers to the EGR because it's part of that system. As such, if your state also has a longer emissions warranty period you might be able to argue that. In my case they gave me a "courtesy" repair. In my experience that usually means that they either recognize that there is a problem that should be warrantied but they don't want to admit it because then they'd have to fix it for everyone, or they recognized that I was the type of calm, respectful, but obviously persistent enough that I wasn't going to take no for an answer type of person that they'd rather not spend days arguing with. Either way I'm just trying to help you with trying again to get them to cover it so you don't end up wasting an entire weekend neck deep in your dashboard.Using the same logic, the engine's radiator is part of the emissions system? I still don't get it. I understand coolant is used for the EGR, but following this logic, if the radiator fails, it could be covered under the emissions warranty???
