SuperJ
No pun intended...
If you can get to them, you might want to check to make sure your cylinder had fasteners have been tightened properly at the factory.
I've been having blown headgasket symptoms for the last couple of weeks.
Finally got it narrowed down and took it in to get fixed to a trusted shop.
The mechanic phoned me to tell me that 2 of my cylinder heads bolts were barely finger tight when he went to remove them. Since the gasket was leaking I still have to get it replaced, but am now wondering if I should get him to check any other fasteners.
My valve cover had fasteners that had totally loosening off when I removed it to do my first cam inspection.
Yay for VW QC!!!!
For the record I'm just rolling over 100k miles and have done the following work in the 2 months. Clutch (dmf failure), Cam replacement, headgasket, and timing belt. Getting to be $$$$!
Yay for VW QC!!!!
