Headlamp Steel Nut Removal
ajh
Ottawa, Canada
Jetta MK5
Anyone know the correct way to get the large plastic hex nuts that go through the steel above the headlamps out? I need to refinish the steel and the plastic parts really won't like the media blast or powder coat oven. I have tried moderate force but they just seem to be deforming.
x1800MODMY360x
AZ, USA
2013 Passat TDI SEL
I usally remove the 4 bolts that hold the bracket down, then the two screws on the headlight adjustment, and pull the bracket up if one or both of those adjustments were stuck.
ajh
Ottawa, Canada
Jetta MK5
So, discovered the answer through the utilisation of butterfingers... They come apart just by pulling on either side... They are not threaded at all.
