jeepinblackdog
I have a 2003 jetta ALH motor that has been completely rebuilt(new rods, pistons, valves) by a local engine builder and I only have 405 psi on each cylinder. It smokes a lot during cold start up (its around 0 degrees here right now) but then smooths out and runs fine but does not have the power it had before and I'm getting low 40 mpg. I have the timing set just below the green line and I have set the IQ to max power. I also have new 1019 injectors and a new vnt17 turbo. also have a karma tdi tune.
My question is this. I originally had a 2 hole head gasket in it and I noticed it now has a 3 hole gasket Could a thicker gasket cause the lower psi (I'm thinking it should be around 550) I have put around 2k miles on it since the build.
Any input would be greatly appreciated.
