head gasket alh 2.0 cc
leonesea
francia
tdi 110cv
hello I need to buy the head gasket on alh pistons 2.0cc, where can I find it? the original now has a diameter of 1.9 cc
brum
Bulgaria
Passat B5, 1.9 TDI, AFN
ALH is not PD :) . And I guess the head is different - probably like most of the 1.9TDI with rotor pump.
Check here - http://forums.tdiclub.com/showthread.php?t=354031, my last post. I'm currently running with metal head gasket from VW Golf 3 1.8ABS petrol engine. It happened to match my piston protrusion.
Yucca
Finland
ALH 388bhp, Polo 6R 2.0TDI CR GTC1752VZ
brum: I have 2.0 ALH, Vogelspinnen also has 2.0 ALH. And you have??? :D
Yucca
Finland
REINZ
Gasket, cylinder head
Nr art: 61-34810-00
EAN: 40 26634 35670 8 Gasket, cylinder head
Engine Code: BGW or: Engine Code: BHW
Multilayer Steel (MLS)
Thickness/Strength: 1,45 mm
Num. of holes: 1 mm
82 mm
REINZ
Nr art: 61-34810-10
EAN: 40 26634 35681 4 Gasket, cylinder head
Thickness/Strength: 1,53 mm
Num. of holes: 2 mm
82 mm
REINZ
Nr art: 61-34810-20
EAN: 40 26634 35682 1 Gasket, cylinder head
Engine Code: BGW or Engine Code: BHW
Thickness/Strength: 1,61 mm
Num. of holes: 3 mm
82 mm
leonesea
francia
tdi 110cv
thank you very much but I wanted to mount the pistons tdi 150cv thank you very much again
vogelspinnen
Singapore
VW caddy
We are using ACV pistons, I had to cut a recess in the pistons for the oil squirrels as they don't match up. And it doesn't really matter what pistons are going in, as long as you are going more than 1.5mm oversize on an ALH block, the BHW gasket will do fine. Just make sure to check piston protrusion!
