jiggseob
- Joined
- Aug 16, 2002
- Location
- Round Hill, Alberta, Canada
A crack, that drips slowly, then drips really fast when I push on it with a finger.
Its an 01M auto, and I can get a free pan off a 2.0 litre gasser - but I have to take it off in the cold - I am told the 2.0 gasser oilpan is the same. Queries on parts site indeed show that oilpan fits 2.0 or ALH-tdi. Part number 038-103-601.
http://www.partsplaceinc.com/produc...keyword=VW+Jetta+Oil+Pan038-103-601&sku=19112
Confirm or deny that the 2.0 gasser oilpan will fit??
Do I need a gasket, or do I use sealant?
There is a bit of a discussion about the bolts near the rear main seal being difficult to reach. I have both a 10-mm-1/4 drive 6-pt u-joint socket, and a set of long ball-end hex allen wrenches. If using the ball-end allen wrench, since its thinner than a socket on an extension, does one still have to hunt and roll the flywheel to find the slots?
It looks like its going to be -23C for the day when I get the oil-pan from the donor car... so I want to minimize my fiddling in the cold...
Thanks in advance, Mathew Banack. Round Hill, Alberta, Canada.
