M MacsMK4 New member Joined Jan 20, 2021 Location 20110 TDI 03 Jetta ALH Jan 20, 2021 #1 Car still throws the code and runs the same after I've replaced the temp sensor, P0182, need help anyone please....
Mozambiquer Vendor , w/Business number Joined Mar 21, 2015 Location Versailles Missouri TDI 2004 VW Touareg V10 TDI, 2012 Audi Q7 V6 TDI, 1998 VW Jetta TDI. 1982 VW Rabbit pickup, 2001 VW Jetta TDI, 2005 VW Passat wagon TDI X3, 2001 VW golf TDI, 1980 VW rabbit pickup, Jan 20, 2021 #2 16566/P0182 - Ross-Tech Wiki wiki.ross-tech.com
C chz17 Veteran Member Joined May 25, 2013 Location Boston, Mass. TDI 2002 jetta TDI GL 5spd, 2004 jetta TDI PD Jan 20, 2021 #3 Did you clean the fault code after replacing sensor? Check the wire harness and socket leave from the fuel injector pump.
BobnOH not-a-mechanic Joined May 29, 2004 Location central Ohio TDI New Beetle 2003 manual Jan 20, 2021 #4 So it's more likely bad wire/connect or Low ambient temperature operation
Wigstdi Veteran Member Joined Oct 21, 2018 Location Pa TDI Alh Jan 20, 2021 #5 More than likely a bad wire I would say around the starter area
