Has anyone upgraded the underbelly on the Golf
bigb
Arizona
2015 Sportwagon S
Has anyone here bought one of the after market skid plates to protect the oil pan on the Mk7? I see there are several, a very stout looking composite one, a steel one and an aluminum one. Some Google results show the Ares to be popular but I wonder if the cheaper, composite one would be better as it looks quite stout and I have seen aluminum puncture, crack and even have objects go right through it.
GreenLantern_TDI
Iowa
2015 GOLF SEL
I also got the Ares plate from ID Parts and wouldnt run the car without it. Too much road debris and uneven drive ways for the risk. That said the plate is great and easy to install and use.
mheat
Shawville, Quebec
15 GSW, 03 JSW
Evolution aluminum plate. 3rd one on 3 TDI's over the years. Mounting system has improved significantly. Very easy on/off for my '15 GSW, which you need to get at from underneath to change oil filter.
Lightflyer1
Round Rock, Texas
2015 Beetle tdi dsg
Any of them can be overcome by hitting stuff if the conditions are right. For what it is worth I haven't put one on my 2015 as it is much higher off the ground than my 2003 was. It was barely 3 inches off the ground and ground down on almost anything in or on the roadway. The 2015 hasn't had any issues so far.
Mrrogers1
Omaha NEEEBRASKA
2011 Golf TDI 6MT, 2015 Golf Sportwagen S TDI DSG
Here is the definitive thread on this subject: https://www.golfmk7.com/forums/showthread.php?t=8532
Every single option from nearly every manufacturer gets dissected. I myself ended up buying the Alltrack’s reinforced plate.
Thanks! Good reading even though I already made my decision and would advise others to do the same. For the price, the value is undeniable. [emoji1474][emoji1474]
Sent from my Pixel XL using Tapatalk
mxtdiguy
Mexico
'16 sportwagen TDI sel 6mt
Which version did you guys get ? Mine has a single ventilation cutout which I think is the DSG version, although I certainly can't see any harm in having it on a 6mt.
Martin Winterkorn
Valley of the Sun
2015 Golf TDI SE w/ Lighting Package
Do you have the part number?
turbobrick240
maine
Golfdave put a lot of effort into that writeup, and that is commendable. I had to chuckle a bit at the end of the first post where he states the underbody trays improved his cars cornering ability. :D
JM Popaleetus
Connecticut
Signature.
DSG Skid Tray (Vented): 5Q0 825 902C or 3Q0 825 902
Manual (No Vent): 5Q0 825 902B
Best prices will be found on eBay, even though yes, you’ll pay more in shipping than the part itself. Or your local junkyard. Expect to pay ~$100-$150 for the pan and ~$50 for the following bolts you’ll need:
Left and Right Bracket: 5Q0825921 and 5Q0825922A
Bolts: N 0195 307 (x6)
740GLE
NH
For what it's worth our DSG Alltrack has the non vented pan, and I'm cool with that, as the DSG has it's own coolant loop.
Also FCP Euro carries the Alltrack pan for about what you can get it from ebay, maybe quicker shipping, but it may be free.
JM Popaleetus
Connecticut
Signature.
I got the pan from eBay and all the bolts from FCP for $200 total. FCP Euro charges $350+ for the pan alone.
I love FCP, but piecing it together is definitely cheaper if you’re willing to take the time.
bmwM5power
Rochester NY
15 GOLF TDI SEL DSG / 15 GSW TDI S 6MT / 02 JETTA TDI GLS 5MT
mine came down to about $110, $77 oem alltrack skid plate ( ebay )shipped from Germany and about 33 bucks for the hardware needed
ssffnomad
Upstate N.Y.
2015, GSW, S, TDI, 6MT. 5/2017
Good Luck on I-90 . Semi,s Blow a Tyre once in awhile
Usually a 11R 24.5 Casing
Ask me how I know, S... happens
bigb
Arizona
2015 Sportwagon S
Can't find any on ebay, just a used one without the DSG vent
hskrdu
Maryland and New England
JM- I can't enlarge the photo on my screen, it looks like the 3Q0825901 from your ebay link also corresponds the p/n you listed above: 3Q0 825 902, for DSG with vent? I guess I need to find 5Q0 825 902B / 3Q0 825 902B (manual without vent).
JM Popaleetus
Connecticut
Signature.
JM Popaleetus
Connecticut
Signature.
Ecs locks in place just like the OEM. It has anchor point in the center front as well.
Sent from my SM-G965U using Tapatalk
The OEM Aero (flimsy lightweight) pan locks into the front spoiler via plastic tabs. Any serious strike will rip the pan right out-from, or out-along-with your front spoiler.
The upgraded OEM pan bolts to support brackets that need to be installed.
hskrdu
Checking in to see if anyone has install pics or instructions for the OEM Rough Road belly pan (Alltrack / 5Q0 825 902B / 3Q0 825 902B) install for a GSW? I have the thread from GolfMK7, but I'm hoping for more pictures and a step by step. Thanks.
mheat
Shawville, Quebec
15 GSW, 03 JSW
3rd Evo plate on 3rd Sportwagen. The MK7 plate is a lot slicker install than the MK4 and MK6 were. Wouldn't run without it back here in the boonies.
MK 7 is easier to get on and off, which makes a difference because you have to change the oil filter from underneath now, whereas on the earlier cars you could do an oil change from the top.
Mrrogers1
Omaha NEEEBRASKA
GolfDave's thread is the best and original. This is a 2 out 10 on the difficulty s scale (1 out of 10 is the factory belly pan) so it's very easy. Follow the parts list and just get under the car. :)
