Never? I realize this is years ago and is a VE TDI, but you've said it more recently too. (quoted so you don't change it
http://forums.tdiclub.com/showpost.php?p=223301&postcount=17
http://www.powerservice.com/products/inject_cleaners.asp
Again Bob posting out of context, To quote specifically and I might add 11 years ago...
"This I suspect cleans out the injector needles and nozzle tips. After seeing the injector tips on the TDI it does not take anything at all to cause clogging in these injectors."
And to emphasize another statement I made "That is until I took the car for a drive came back and the smoke was reduced a bit. I went for a good hard drive 4000 rpm+ revving and keeping a high load on the engine. When I got back the "TDI smell" had returned! The smoke was reduced noticably but I was just amazed that the CAT had lit off after all that time."
In other words the Hare drive and getting the engine loaded up was enough to get the Catalyst hot enough to start oxidizing the exhaust once more.
And Power Service makes the same claims I do but use the data from the "Cummins L 10 Injector Test" this does not state that "REMOVES" debris from within the injector only that it "PREVENTS" or cleans the injector in terms of carbon on the external surfaces of the nozzle. These certain residues and the "Decarbonization" (as they call it) is related to the reduction in soot at the external outlet of the nozzles...carefully worded but their is no magic bullet statement in anything above. A reduction in soot on the OUTSIDE of the injector is purely due to the use of 2Ehn which increases the cetane (to be specific about what additive is doing what). Increased cetane can and will lead to more complete combustion since the fuel auto-ignites quicker in turn giving more time for the fuel to combine with available air.
So Bob to put all this into CORRECT context, the cleaning that is going on in my statement from 11 years ago and in respect to the Cummins L 10 test and Power Services statements as well as the noted improved function of the catalyst has nothing to do with the internal regions of the fuel system but only in respect to reductions in carbon on those surfaces directly exposed to the combustion gasses.
Again, in order to clean a fuel system component it requires the used of ultrasonic cleaning when attempting to clean or remove accumulated deposits INSIDE the injector.
