thecause17
I've been searching the forum here for some answers, but can't seem to find anything that is similar to my scenario.
For the last two days Ive noticed that on a cold start, specifically the first start of the day, it takes longer than normal to start. It cranks fine, but takes 3-4 seconds to actually fire up. Usually the car starts almost immediately.
Also, the car stalled twice on me yesterday. Both times were in parking lots while coasting at low speed. ALso noticed some roughness at low rpms at the same time. No cel or any other lights except for the battery light after stalling for obvious reasons (no charging).
Hooked up VCDS, no faults present.
Info on conditions, temps have been mid 60's to mid 70's here the past few days. I filled the car up shortly before this, same station I always use. There's probably only 100 miles on this tank of fuel right now. Fuel filter was changed at 60k miles, currently have just under 66k. I'm thinking I may have gotten some bad fuel or water in with it. I may open the fuel filter canister this afternoon to take a look for water and/or metal shavings. This doesn't seem consistent with a failing HPFP as it's only been happening at basically idle. Fuel pressure at idle is consistently around 5000psi according to my scan gauge which reads right from the car's sensors. Hitting 26kpsi at full throttle higher rpms.
Was slow to start this morning again, but hasn't stalled on me yet and ran fine on the 20 miles or so I've driven it today.
What do you guys think my next move should be. Like I said, I'm going to open the fuel filter canister and have a look, and then rerun the fuel pumps via VCDS again to get out any air I may have introduced.
