Hard Starts
BEETLE BUG 99
Central Pa.
1999 Beetle
I have been having problems with my Beetle being hard to start when it is warm.It starts OK when it is cold although, it seems to crank a little more than it has in the past.The warm starts concern me because it cranks quite a bit before starting.Any thoughts?
gforce1108
Newburgh, NY
04 Jetta GLS BEW, 14 Audi A7 V6 TDI, 13 Porsche Cayenne V6 TDI
This is the photo section, not a technical forum but I'll point you in the right direction...
There is a known hot start problem with 98-99.5 A4 TDIs. Pull the connection to the coolant temp sensor and start the car while it's hot. If it fires right up you have this problem (this test will probably cause a check engine light).
There are a couple of solutions - most popular is getting a good tune. The tuners change the fuel maps to start injecting fuel below 250RPMs when the car is warm (70 degrees, I think). The other, cheaper solution is the hammond mod. It's a switch or relay that opens the temp sensor connection. I wired a switch up on the dash and it makes a big difference. Do some searching on here for the directions.
Also make sure your battery is good and connections are clean. If something is preventing the engine from turning over fast enough, fuel will not be injected.
USdan
Log Island NY
99 new beetle hard starts
I have been suffering with hard starts in warm weather. The engin is cold from sitting all night or a long time. I must crank several times and for a long duration.
If the weather is very cold, it starts right up. I'll try disconnecting the temp sensor.:confused:
Dan
babydoll
wv
01 jetta 5 spd 01 golf 5 spd cruze diesel 9 spd auto 17
Same Problem
I Want Too Post A Picture I Have On My Computer, Of My Beetle.
If U Can Send Me A Email Address I Can Do It That Way , Havent Figured This Way Out Tahnks
