rockyrunner99
I have a 99.5 golf. It has 298,000 miles on it now. I bought it with 212,000 on it. This winter, it has really been starting hard, anything under 30 degrees it takes about 4 seconds of rolling over to start. The glow plugs are fine, we cycle the glow plugs twice before starting it. I am worried it has lost compression. I did go over on the last 2 oil changes cause I have been busy, I know how bad that is and I may be paying for it now. It has a new Air cleaner, that helped some, I cleaned the snow screen the best I could with it on the car. The battery is 2 years old, and it seems to roll over fast enough. It does have a little smoke on start up. but goes away within seconds. It does not use much oil at all 1 qt in 10,000 miles, and I use shell rottella T6 all ways have.
What other issues can I check? I have checked compression on a gas engine, what is different about doing it on a diesel? If it is low on compression, any guesses on the life expectancy? I am not sure the car is worth an engine rebuild. Thanks
