newdie
Oh swell. Subscribed.
Without question, however there's no reason at this time to assume this is anything to start losing sleep over. Some are beating the drum like it's a catastrophic issue that's going to have an effect on everyone.There are lots of issues here that start as isolated cases. Balance shaft issues, BEW or '01 ALH cam wear, lift pump failures--you get the idea.
There are also several independent reports that there is a TSB due out soon related to moisture or icing in the intake plumbing. If so, it may shed some light on what is happening.We don't know anything about the car or cars in question. Were there any other influences, etc...
One byproduct of combustion is water vapor.Low pressure EGR in a CRD is sent thru the inter cooler,so water condenses faster in colder weather in the IC and not so much when warmer.
I can appreciate your skepticism, which is an essential part of critical thinking. If I am guilty of spreading gloom and doom, then I will apologize and we can have a good laugh at my expense - there is no harm intended.Without question, however there's no reason at this time to assume this is anything to start losing sleep over. Some are beating the drum like it's a catastrophic issue that's going to have an effect on everyone.
We don't know anything about the car or cars in question. Were there any other influences, etc...Discussion is fine, but spreading fear is not. At this time there's no evidence that this is epidemic or even the cause of some, most, or all rough/cold start issues. Some in this forum seem to buy into doom and gloom hook, line, and sinker.
Did the engine continue to run with a bent rod? Or did it get torn down due to the damage?When a piston approaches TDC, the leverage of the crank provides a huge mechanical advantage. So even at low rpm it is possible to bend a rod. Not saying that it would happen, just that it is certainly possible. I think compression tests are in order for cars that hydrolock. That will tell the story.
I bent a rod on a 6-92 detroit on hydrolock with the starter.
6V92 should be 19:1 compression ratio for NA, 6V92T would be slightly lower.I agree that it couldn't hurt, but to say what happed wasn't a hydrolock doesn't make sense.
As for your case, whats the compression ratio for that detroit compared to our? how big is that starter compared to ours?
It ran, but misfired on cold start. Had a cracked injector tube that leaked coolant into cylinder. Misfire was probably due to wet cylinder. Head had to come off to fix tube, piston to deck measurement showed piston was low at tdc.Did the engine continue to run with a bent rod? Or did it get torn down due to the damage?
This was a TA version, 550hp. The CR is 17:1, lower than the NA and T versions.I agree that it couldn't hurt, but to say what happed wasn't a hydrolock doesn't make sense.
I've already got something in my intake creating a vortex... it's called a turbocharger.Maybe if we install one of these downstream in the intake it would create a vortex and atomize any sludge before it's drawn into the combustion chamber. Someone cut up a beer can give this a try.![]()
Good golly, I wish I still believed! All I asked for was foglights from ECS Tuning!I have asked Santa for a leather aviator cap, flying goggles, and an "Intercooler Heat" button to help me on my long commutes.![]()
It costs me time, energy, and laying on a cold concrete floor. You need to remember that for some of us, these cars aren't hobbies. This is VW's issue.Doesn't cost anything
Sure it is. I agree. But at least if you want to you can do something about it. Not having to worry would, for me anyway, make it worth the effort.It costs me time, energy, and laying on a cold concrete floor. You need to remember that for some of us, these cars aren't hobbies. This is VW's issue.
I've noticed my JSW TDI exhaust is more steamy in the cold weather compared to my previous TDIs. The exhaust is steamiest during the initial warmup right after a cold start. For owners who like to let the car idle for several minutes to try to warm it up before heading out, it's probably a bad thing to do because this is when the exhaust is the steamiest and the low pressure EGR may ON during this time. These cars don't warm up well in the winter by letting them idle because they are so damned efficient. They need to be DRIVEN to warm them up. Start it up and GO right away!I think this is the elephant in the room. Regardless of ambient humidity the engine itself is producing large quantities of water all the time. Previous engines used only high pressure EGR meaning the exhaust was diverted directly from the exhaust manifold to the intake. The new CRD motors divert some portion of the low pressure exhaust back to the turbo's intake to be re-compressed. Now this low pressure exhaust is extremely high in water content. How high? Think about the water vapor and even liquid water dripping from exhaust pipes all the time.
Thanks for checking and posting back. It seems like whether good or bad, a little goop and moisture or "goopy emulsion" is "normal". Anything that is watery should get mostly blown through with each use, and the sticky stuff stays - this makes sense.I've put about 4400mi on the car since the last time I opened the IC hoses, so I decided to check them again today. Since I removed, cleaned and replaced the hose seal on the driver's side the third time I had the hose off, it now has only some oil film on the outside and no drips. The passenger side hose still had some goop and a little bit of water in it, but it still hasn't topped the first time I removed the hose. That was the one that a big mess came pouring out.
If anyone of you haven't checked the hoses yet, I think it's well worth the effort to do so. From what I saw this time, I don't have any problem waiting 'till I change the oil in about 6000mi to check the hoses again, but I'm glad I did it.
