There are a huge number of situations that vary with what is going on in an individual car and area.
1.. No water problem.
2..Engine locked by water on top of piston and the engine will not turn over.
3..The rod bends and the hydrolock is not complete (small minor bend to severe bend).
4..Hammer that does not lock engine or bend rod.
5..Hammer that blows head gasket, bends rods, cracks pistons, and all sorts of things (right now rare, but how many slight bends result in severe problems after 100 (?) water problem starts?
6..Other
I think we should discuss when to remove water from the low point of the intake tract, and seek to keep the water / frost out of the intake system.
When water might best be removed
1..Shortly after parking the car after a trip (? how long). The heat from the radiator, engine compartment thaws the intercooler and the water trickles into the low point but has not frozen yet (garage or outside ?)
2..Install a temperature sensor in the low point and drain when the temp is above freezing (fitted with alarm?).
Factors that might effect drain
1..Decide how flat to park car to get the best drain (parked on slope with front, rear, driver side, passenger side or combination (high low).
2..Decide on the worst parking situation.
Coming up with a strange parking angle to allow engine RPM to remove water sounds like a poor option (I will mention it anyway).
I think discussing the draining of water is better than discussing the RPM to remove water. Removing water through the cylinders sounds mighty dangerous to engine components. I am sorry we have to discuss draining the water, but denial of the problem does not seem to work.
The other option is still discussing the EGR cooler area and the low pressure EGR gas / water / moisture flow. Sorry we have to evaluate the whole operation and possibly re-design the engine in that area.
We just need to discuss the problems and solutions and not look to others as the only sources for possible patches.
I totally realize I am a shadetree, jerk from Mississippi. I realize that there are those who have more energy and drive than I might have. Facing a $10,000 (?) complete engine replacement might motivate some to do beyond what they usually do.
Finally the larger, public TDI CR crowd is finding the tdiclub. Many are looking for solutions (not just hearing the problem). I know a bolt in simple solution would be nice, but the extent of the situations that cause the problems will require (? ? ?).
eddif
