Hard Start / No Start - Is your intercooler frozen? Check Here!
GraniteRooster
Upper Valley NH
'12 JSW 6MT
Very nice work UberVW - thanks for posting pictures of your new kit and thanks for your persistence. I for one will be contacting VW to ask them what they have to offer. It would seem they've been doing some significant work to put that kit together and I would like to know what it is supposed to do. I haven't talked with my friendly VW rep in a few months - seems like a good time to ask some questions :cool:
kenford
Canada
2010 Jetta
Spoke to my dealer in Winnipeg today and they confirmed that they had received a TSB referring to the same part number as listed earlier.
Will not be a recall but rather a fix on a per case basis. They have ordered the parts to fix my 2010 as it was towed to the shop four times over the winter.
TDiSkater
Northern Suburbs Chicago
2011 JSW DSG Salsa Red
Might be nice to get that service bulletin number when you have the work done. It will make the conversation easier as winter approaches. I never like to leave it up to them to find it. I had a couple of weird starts last winter and they totally dismissed me when I asked about intercooler problems.
740GLE
NH
nice all the ammo we need to make VW step up.
Should this be a sticky with the first post modified and TSB in bold?
El Dobro
NJ
2017 Bolt EV Premier, 2023 Bolt EUV Premier
I wonder if this is a patch and not a cure.
El Dobro
NJ
Short of eliminating the LP-EGR system--or LP-EGR duty cycle, how else would they cure it w/o affecting emissions?
Has it been proven that's where the problem comes from?
MayorDJQ
Williamstown, Mass
'10 Golf 2dr 6m, sold.
Proven? No. The main source of the problem? Quite likely.
Driving style doesn't seem to matter much, as people who drive spiritedly have had the problem as well as pussyfooters. Region of the country doesn't seem to matter much, as it's happened to people from New England to Texas.
The AHU, ALH, BEW, BRM, and their European counterparts have not experienced the sludging/icing problem. The CR engines have the LP-EGR system, which is introduing moisture to the intercooler. If it were a matter of driving in damp or wet weather, then the earlier generation TDIs should experience the problem. But I never had that problem in 150k and 8 New England winters in my ALHs. 9,900 miles and a few months of winter was enough to produce a TBSP of water & line the hose with green sludge in my '10.
740GLE
NH
proven only in the sense it's the only thing different/new compared to all other TDIs.
quadrun1
Fairfield County, CT
past: 2013 Passat TDI SE 6M, 2010 Jetta TDI DSG
Exciting that there's a "fix", but VW might be correct in making people wait before having this installed.
I drove a SAAB 9-5 in the past and the EGR was problematic, so much so that I think there were 5+ revisions/patches to the system!
My gut tells me that this kit is not the "final answer".
Jason
bhtooefr
Newark, OH
None
Proving it once and for all, and posting the proof on TDIClub, would be deleted or locked by a couple of the moderators, as it involves an EGR delete.
El Dobro
NJ
In the CCV hose that goes from the valve cover to the turbo inlet there's something that has wires going to it. Does anyone know what it is? I haven't found it in the CR self-study yet.
MayorDJQ
Williamstown, Mass
EWD #127/8 in Bentley mentions a heated CCV N79. That would be my guess.
El Dobro
NJ
There's 5 pages on the new CCV system yet it's not listed. A CCV heater, interesting.
Fixmy59bug
Las Vegas, NV
2015 Passat TDI SE
Not just TDI's, but a lot of vw's. My 2000 Jetta 2.0 had a heated ccv valve built into the intake boot which was fed crankcase fumes from the valve cover.
El Dobro
NJ
Interesting, and exactely what purpose does it serve?
nicklockard
Torque Dorque
Arizona
It prevents the CCV from becoming plugged by frozen condensate. The condensate is pulled into the intake air by Bernoulli principle, which cools it off.
MonsterTDI09
NoVa/NJ
2010 Jetta DSG/ up keep on 2009 Jetta DSG 2006 Jetta Pag 2 in North SEA Green
I wonderer why they took this root for the fix? In stead blocking off the I/C in some fashion?I my guess my quot is the answer:D
