Two weeks ago I opened up three cars intercooler hoses while on the lift... All with varied mileage and different owners. Each had no water and no real oil coating on the inside. I suspect issues may be related to driving habits. Each of the car owners have lead feet and drive very spirited on shorter trips... I am working on checking a few more to see what is going on.
Seriously?
You seem to have a big miss understanding about this issue. Once condensed inside the intercooler, the water will not simply stay inside.
Air is being sucked through the intercooler way too fast for water to be able to stay inside the intercooler for any long period of time. Any water accumulated inside is not going to "pool' up over time until someone opens the hoses and drains it out. It gets sucked through the engine within minutes if not seconds....depending on driving conditions, of course.
This issue is due to recirculated exhaust moisture (natural product of combustion) freezing inside the cold intercooler during cold days. Once the the temperature gets above freezing inside the intercooler, the ice of course melts, were it will puddle up inside the intercooler and wait to be sucked into the engine during the next start up.
This usually shows itself at start up in ~35-40 degree weather after driving in below freezing weather. The engine will have a hard time starting (its hydrolocking on the ingested water). If the owner gets the engine started, it will run like "its on three cylinders" until the water is sucked through the engine...at which time the engine will return to normal operation and idle and run as before. But, sometimes enough water can be sucked in at once to cause the engine to break something as water does not compress very well. I've read about three people having to get new engines due to internal damage (usually caused by bent rods, broken glow plugs causing cylinder damage, etc.)
You can't simply randomly open up TDI's with the LP-EGR system and expect to see water just sitting around inside.
I had this issue when the weather was 19 degrees for a day or two, then warmed up to mid 30's. I found almost 2 cups of water inside my intercooler when it wouldn't start up after sitting in garage through the night (~38 inside garage). Only tried to start it twice. Both times, it cranked fine but immediatly and suddently died.
Again after driving to work in 19 F weather....When heading home for the day, I first tried to start it and it idled like crap. I immediately turned it off and drained another 1/2 cup of water out.
Warmer weather (above freezing)....opened up intercooler. Nothing. Dry.
You won't find anything during warm weather.
How many people have complained about how their car would crank but suddently die in these conditions, if they could get it to restart, it would run very very rough for about 5 minutes.....as the water was being sucked through the engine.
This is a huge issue. Sucks that I can't feel comfortable driving my car in cold weather.
Very curious how this issue wasn't discovered in LP-EGR product development.
VW still says, "Engineers are aware if this issue, and are working on a fix, but nothing yet" As told by VW CustomerCare.....
The LP-EGR system is the cause of this issue. Without it the car won't meet TierIIBin5 emissions....so they can't simply shut the LP-EGR system down during cold weather. They will have to re-route the re-circulated exhaust around the intercooler during cold weather. Expensive fix.
VW told me they would have a fix by the first week of March 2011. Still nothing..... as I've called recently to check on status.
Love my TDI overall, but amazed at how this unique LP_EGR system wasn't engineered very effectively.
