dweisel
Must be ''PICK ON DWEISEL DAY'' Remind me next year and I'll stay away that day. lol.wow? really dwesel?
trusting the dealer for info?
dweisel
It SUCKS! At idle it SUCKS! At 2000 rpm it SUCKS! There is always suction. Maybe my turbo is install backwards? As I see it 4 out of 5 bets need to pay up. The other to be settled at a later date.Not so fast.
Put the hose back on, leave the mechanical fitting loose.
Idle the engine.
Is it sucking, blowing, or neither?
Well said, enough of thisThat's not a valid test. You've disconnected the air inlet to the engine, of course it is going to suck!! The question is what is the pressure in the system when it is all connected.
This diversion is a waste of time. There is a real problem with icing/thawing/hydrolock. Whether there is a slight positive or neg pressure at idle has nothing to do with the problem nor the fix.
Slow down, Hot Rod:
You disconnected the hose on the passenger side, right?
That's the hose going to the intake manifold, so you just turned a turbo-charged engine into a naturally-aspirated engine. Of course it's going to suck when disconnected and the engine is running. The engine will draw in air to keep running.
Your experiment is invalid. Reinstall the hose so that the charge-air system is intact and operating normally. Then tap a vacuum gauge into it.
I give up!Slow down, Hot Rod:
Good.I give up!
dweisel
Yes, I had another episode today as well. Not amusing.I had a hard to start, nearly no start again today, this is not good...
please VW, ignore the non-sense in here, this is a real problem, please fix this for us!!!
Nice Diagram![]()
I've left off the valve at the intercooler, the valve at the HPEGR, and the valve at the LPEGR.
Air comes in the airbox. Follow the path. Realize which hose you disconnected, and what happens to the air that's coming in there. When you realize what happens to that air, you'll see why that's not the cause of the intercooler icing.
What valve would there be at the IC?I've left off the valve at the intercooler, the valve at the HPEGR, and the valve at the LPEGR.
That isn't really a throttle valve is it? The only valves I know of in there is the anti-shudder valve and the intake runner valve.[/IMG]![]()
There's no ASV on the CR engine. The "throttle" is a throttle, but not like on a gas engine. It's not there to affect the air/fuel ratio or create vacuum. It's used to control airflow and in conjunction with the EGRs to regulate EGTs.That isn't really a throttle valve is it? The only valves I know of in there is the anti-shudder valve and the intake runner valve.
My interpretation is much like yours in that the throttle is not there to create a vacume or affect air/fuel ratio. I think it might just be there to help the motor shut down quickly.The "throttle" is a throttle, but not like on a gas engine. It's not there to affect the air/fuel ratio or create vacuum. It's used to control airflow and in conjunction with the EGRs to regulate EGTs.
Okay guys, its pay up time! Go remove your belly pan,disconnect the coldside intercooler hose at the mechanial fitting and place your hand over the end of the hose. IT SUCKS! In FACT it SUCKS so much it will colaspe the hose and stall the engine.
Please remit a $20 contribution through PayPal to the tdiclub in my name.
Thanks guys, its been fun.
dweisel
