Hello everyone! A while back, we were discussing a means to drain the lower hose of our intercoolers. Short term update is that it is possible and doesn't clog up with the emulsified oil goo, as long as it is drained frequently. The electric version is automatic, and drains every time the key fob is beeped. Here is a link back in the spring:
http://forums.tdiclub.com/showpost.php?p=3785173&postcount=2915
Here is a much simpler version, manually actuated:
Look for the ring pull, just beside the fog light.
Video:
http://i1059.photobucket.com/albums...oler drain Picture Install notes/DSCI0458.mp4.
There are a couple out for testing with good results. Opening it for a few minutes after a drive, when the car is warm, drains a surprising amount of water, depending on driving conditions. During a long 2000 rpm highway drive, seems to produce the most water. Throw in a regen, the water increases dramatically.
A couple questions came up from our members:
1.) how often to drain? - Frequent draining is best, you would be surprised how much water comes out. I drain mine daily.
2.) will it work in freezing temps? - No, car must be warmed up. The accumulated ice thaws during a drive, then drain it after a drive.
3.) will the valve freeze up? - So far, no. It gets heated naturally from being right beside the oil pan.
4.) how about a lock? - The ring pull is very well hidden and won't get caught on bushes or the car wash.
This will not fix the intercooler issue, but just adds piece of mind that not water is accumulating in your lower hose.
Nothing has to be modified on the car, except cutting 1-/14" off the $100 intercooler hose to install the barb:
The hose will still reattach to the original position, if the barb is removed.
All the best,
