If you turn the crank counter clockwise it puts tension on the back of the belt and slack on the front, which is the opposite of how it operates. If you need to turn the engine ccw for some reason, do it from the cam sprocket. This will keep the slack in the belt by the tensioner where it should beThen I realized when I would lock camshaft, loosened the 3 bolts and turned crankshaft backward then forward, the tensioner needle would still be in right place but slightly different compared to if I only moved the crank twice in a correct direction. It seemed like going opposite direction, then forward direction caused slightly different tension in belt compared to only clockwise direction
You don't need VCDS to do the timing belt, unless you want to run the fuel pump (assuming you unhooked any lines). Yes, the new belt is tighter than the old and will probably stretch a little, so I think most will set the tensioner to the right (tightest) side of the adjustment window.Hi everybody, after replacing timing on the TDI you take VCDS and check in the programme how right you adjust 1-st die point. The new belt tighter vs old . And yes I’m use VW tool for lock crankshaft and camshaft when replace timing
Will, you're absolutely right. But you have to turn the engine CCW when you are adjusting the timing if your crank hole is to the right when you cam is locked. Once you do your 2 clockwise turns, then you try to fit the pins and they do not fit after you locked the crank, the procedure has you remove crank lock, move the crankshaft until the camshaft pin fits, then you have to loosen camshaft sprocket and decide where you need to move crankshaft to re-pin it. In my case, crankshaft was always off the hole to the right. Which requires crankshaft to be moved clockwise up to max camshaft window allowance, then move back clockwise until pin would enter the hole. You cannot tighten from camshaft when you loosened your 3 bolts. But moving maximum CCW and then moving back CW still created different tensioner tightness that after 2 revolutions. Hence the reason for my modified re-pinning where I purposefully tightened the crank pulley where it would barely not fit into the pin hole. And after 2 revolutions it would be a perfect fit. The normal procedure always produced same effect. After 5 attempts, I had to adjust the technique as to how I pinned when tensioner is not properly slacked and once I started to move crank CW only, then the tensioner slack was correct and pins fit. That was my goal and that was repetitive x 3 where after 3 double crank rotations, both crank and cam pins would fit perfectly, and that was a perfect job. HPFP did not fit, but was very close.If you turn the crank counter clockwise it puts tension on the back of the belt and slack on the front, which is the opposite of how it operates. If you need to turn the engine ccw for some reason, do it from the cam sprocket. This will keep the slack in the belt by the tensioner where it should be![]()
On UDS ECU, you can't get into measuring blocks.Yes you need VCDS. I’m not first who read information about position camshaft and after make adjusting. 1st connect VCDS, go to engine. Go to Block measuring . Activate group 004 and check parameters « torsion value « they can be from minus to positive numbers. We need to make them 0. After you loose 3 bolts on the sprocket and mouve left or right. And again check camshaft position . Internet full of vidéo how make camshaft adjusting using VCDS. Good luck
IMO would do this one of these ways (of course you got your engine in time, just for discussion)Will, you're absolutely right. But you have to turn the engine CCW when you are adjusting the timing if your crank hole is to the right when you cam is locked. Once you do your 2 clockwise turns, then you try to fit the pins and they do not fit after you locked the crank, the procedure has you remove crank lock, move the crankshaft until the camshaft pin fits, then you have to loosen camshaft sprocket and decide where you need to move crankshaft to re-pin it. In my case, crankshaft was always off the hole to the right. Which requires crankshaft to be moved clockwise up to max camshaft window allowance, then move back clockwise until pin would enter the hole. You cannot tighten from camshaft when you loosened your 3 bolts. But moving maximum CCW and then moving back CW still created different tensioner tightness that after 2 revolutions. Hence the reason for my modified re-pinning where I purposefully tightened the crank pulley where it would barely not fit into the pin hole. And after 2 revolutions it would be a perfect fit. The normal procedure always produced same effect. After 5 attempts, I had to adjust the technique as to how I pinned when tensioner is not properly slacked and once I started to move crank CW only, then the tensioner slack was correct and pins fit. That was my goal and that was repetitive x 3 where after 3 double crank rotations, both crank and cam pins would fit perfectly, and that was a perfect job. HPFP did not fit, but was very close.
