shirish_bh
- Joined
- Nov 9, 2000
- Location
- Auburn Hills , Michigan
Hi,
This topic has been discussed before. However I did not find whatever I am going to write. So read on!
The hard shifting doesnt seem to be a problem. It is just an inconvienence that goes away in a couple of minutes.
We all seem to have gear shifting problems when it is freezing outside, espicially when going from 1st to second. Temps are routinely near zero here in Auburn Hills , MI.
I tried a small trick, which most of you may have heard, which helped me get a smoother shift when cold. That is "Double declutching".
The sequence is:
from 1st gear - declutch to shift to neutral - engage clutch in nutral - declutch and shift to second.
Try this sequence out and you will be surprized by the results.
My car : 2000 Golf TDI/GLS, Cold weather, Luxury.
The sequence is:
