machinebaby
Hi all,
I have a 2003 ALH MKIV Jetta Wagon, 220K miles. Bought it 18 months ago with light mods including larger injection nozzles. Has developed an exhaust leak that I haven't addressed yet.
I have done some searching but still stumped, please help.
I had a bad leak in my booster, making a hissing sound that stopped when pedal depressed. I actually still had normal braking capabilities despite the bad leak. I replaced the booster and sure enough it was torn.
After replacing the booster, I developed hard braking, limp, and A CEL. I have no vag com or code reader.
I checked the main hose from the pump, but it looks fine. One note, when putting the hose into the new booster, the sealing grommet pushed through and dropped into the booster. I bought a new grommet and properly installed the hose using the new grommet, but the one that fell into the booster is still in there. Not sure if that makes a difference but there you go.
There was oil coming from the pump so I removed, cleaned, and rebuilt it with the reseal kit from RXTech.
Still hard braking, limp, and CEL.
I checked the one way valve, it was faulty so I replaced it. No help.
The lines were brittle so I got a line replacement kit with german hoses and replaced all the vacuum lines. I snapped off the nipple on the reservoir during that process, so I replaced the reservoir too. Still hard braking, limp, and CEL.
I had new MAF, N18, and N75 on hand so I put them in, no change.
I would like to do a full vacuum check of the system but I haven't been able to fine a newbie-friendly step by step on that, can someone point me to one please?
Anything else I am not thinking of?
I am going to try to borrow a code reader today, and will post results when I get them.
Thanks in advance.
Thanks in advance.
