Has anyone any experience of these?
My Audi 80 doesn't have headlight relays, because of this the switches are prone to burning out and also a voltage drop at the bulbs isn't uncommon. Whilst I've checked the volts drop and it's ok I was going to fit relays just to try and avoid the switch from burning out.......... but then I thought about fitting LED bulbs.
My concern is while they look bright, is the throw/projection of light any good?
(incidentally my car has working headlight washers and a switch to raise/lower the beam height)
