Thanks for the info; I really want it all fixed correctly. And what's your opinion on *getting chipped*? If you've got time to type a few more words, I'd appreciate your insight. And you need to realize that you'll be explainin' this to a "Dumb and Dumber" type.oilhammer said:It will get a new water pump anyways. Everything in the t-belt pathway will be replaced.
It is possible they tensioned the belt improperly, or turned the tensioner wrong, or did not have it indexed correctly...who knows. I KNOW they installed the belt wrong, the tell-tale paint marks and pump cranked way off to one side confirm that with zero doubt.
01M service runs about $250, skidplate is $600 installed, injector upgrades for your car not too bad because I can swap in some good 5-speed units for a couple hundred for you if you like. I have one customer that has a 2002 Jetta 5 spd with only 58k miles on it that was purchased new and only maintained by me that would be a good donor as he wants to upgrade his to the next biggest.
Bye for now,
William
