yahjnby
- Joined
- Oct 14, 2017
- Location
- Mill Valley Ca
- TDI
- 1998 New Beetle TDI ALH 1.9 Part owner Sencond New Beetle 98 TDI ALH and a 2002 TDI New Beetle
Hi.
My 98 manual new beetle's timing belt broke on the highway two years ago and I became the proud owner of a project car. It was at about 180k miles. Over the last two years, as any time allowed, I have rebuilt the engine with help from Frank06. Very cool!
But my pump sat with b99 biodiesel in it for two years. I tried to start the car but had no fuel at the injectors. I gave the pump a good external scrubbing. I pulled off the quantity adjuster and there is a brown film on everything in the pump. I had to lightly unstick the quantity adjusters ring on the pump shaft. Frank said to try and fill it with diesel purge and let it sit. I siphoned the old biodiesel out of the body and poured in diesel purge. I sealed it up and tried to prime it more using more diesel purge and a mighty vac.
So that's where it stands now. I guess I'm glad nothing made it to the injectors.
Has anyone had any experience cleaning out the film? It rubs off. I'd pull the pump apart, but I understand you can't get it timed correctly afterwards. I thought I saw a thread that indicated it could be done with a dial indicator, but I did not bookmark where I saw that.
I'm having a hard time priming it at the return line. I get a vacuum of 30 on my mighty vac, a bunch of bubbles, and a very slow flow into the pump.
I fussed with things a little. See if anything helped.
I pulled the shutoff solenoid off and cleaned it. Poured diesel purge in the hole it came out of, and it dribbled out one of the delivery valves. I rotated the engine and got it to come out of the other three.
I cleaned out the pressure valve on the return line at the top of the pump.
I'm thinking of cleaning the regulating valve near the pump intake. I feel like I'm tinkering at the edges with my experiments if the stuff in the body of the pump does not dissolve.
Any experience would be helpful.
I pulled another pump off a manual new beetle at my local pick n pull. For $45 I figured it would be good for practice or for spare parts, but I'm wondering if I should just swap that one in. After looking inside first of course.
I'm waiting for viton seals for my current pump, assuming I can get it working, so I can switch and use the new renewable diesel which I can get locally.
While I wait, I thought I'd ask around.
Here's a pic. yum yum. lol
