MrBigTruck
- Joined
- Aug 24, 2009
- Location
- Kansas, USA
- TDI
- 2000 Beetle, 2000 GTI ALH swap, 2006 Jetta, 2006 Jetta, 2008 Mercedes GL320 CDI
This is my build thread & TDI swap for a MKIV GTI formerly a VR6. The timing chain on the VR6 was broken. We are swapping in a 2.0 liter ALH engine.
As she was the day I got her
Engine Pulled out
Turbo
I'm not sure about the turbo yet. Something 2260 based; maybe a 2265.
The block has been overbored to 2.0 liter using BHW pistons on some H-beam rods. They are the second oversize so it is all the way maxed out size wise on the pistons.
Pistons
Rods
Block on the stand:
The pistons have been ceramic coated by Swain Tech. I also got the main and rod bearing shells coated by Swain Tech.
Pistons:
I have a built head with oversize valves and a high lift cam.
Camshaft
Intake Valve
Exhaust Valve
Underside of the head:
Camshaft view of head:
I have a 12mm IP but I may end up using an 11mm. I've read mixed reviews on the 12mm.
IP
12mm IP Head
I have .360 Gibonta injectors.
Injector Nozzles
I decided not to use the tubular Audi style manifold I got from 3L3M3NT but instead got the V-Band style for the BMW style turbo the same way he did. It looks like it flows a lot better to me so I went that direction. I will either re-sell the manifold or hold onto it for another build since I have one more ALH block.
Exhaust Manifold
Tubular intake manifold
Intake Manifold
Pics of the intake and exhaust manifold:
3" Turbo Inlet Pipe
TIP
Engine Pulled out
Turbo
Pistons
Rods
Block on the stand:
Pistons:
Camshaft
Intake Valve
Exhaust Valve
IP
12mm IP Head
Injector Nozzles
Exhaust Manifold
Intake Manifold
3" Turbo Inlet Pipe
TIP
