DanG144
The more the merrier.
I have a spare 1Z/AHU TB kit on the shelf. They are here on approval from Aaron. Settle up with him and I'll bring it. I also need to know if you want the basic kit or the deluxe kit.Dan, sir?
Is there not a 'vendor' that is bringing discounted OEM stuff to the GTG that we can order?
I need a few A3/B4 fuel filters, and perhaps a T/B kit for b4....
plus an old 1.6 TD (ECOdiesel) t/b kit.
I think Aaron(BleachedBora) has in the past?
Vendor attending, please PM me about the parts above.
Thanks..
I might have the fuel filters, too. Same deal, settle up with Aaron and he'll refresh my stock.
At this time, looks like it will be myself, Eric, and Rachel! We can put her to work with the food....
Bruce
OK great. Save us a spot between the house and the shop to park the pig.Several people have stepped forth, Wade.
No problem.
Hey! I remember you!It's been awhile since I have been to a GTG.
I have several things to do. I hope someone has the tool to change the DSG fluid as I lent mine out and it never came back.
Redo my RC1+ tune since the egr delete, Change DSG fluid, if Vagcom available check for codes, get coding right on Euro Tail lights, Pull Valve cover and check the cam lobes.
I will need an addy or directions, have my trusty Garmin GPS.
Hi Tomo, yes it has been awhile. Will I see you at Dan's on the 28th??Hey! I remember you!![]()
Hi Dan, I have done my fluid before and I figure sometime during the day to get it up on the lift and do it. I had a Vagcom last time I did it and temp wasn't an issue but I could see in the heat of summer and no wind. I might throw a 20" box fan in the car and bring it with me that should accelerate the cooling process.Please go to the first post, click on the google document spreadsheet.
One tab has a sign up sheet, another has the address and contact information.
We do have a DSG fluid tool available.
Remember, you guys that want to do a DSG fluid service, that your transmission must cool for several hours in order for it to be below the required temperature. How long depends upon ambient temperatures and winds.
One other thing to consider. Works a treat. I can bring a funnel setup.Please go to the first post, click on the google document spreadsheet.
Sounds good to me I will make my reservation.Just checking some hotel prices nearby... Hyatt Place 17 minutes down the road is $79/night if you bring a can of food for the food drive, or $80 non-refundable, or $85 regular rate. Not bad!
I believe this is where I stayed the last time I went to Dan's GTG. It's not too shabbyJust checking some hotel prices nearby... Hyatt Place 17 minutes down the road is $79/night if you bring a can of food for the food drive, or $80 non-refundable, or $85 regular rate. Not bad!
