Requesting assistance or supervision with injector install
Requesting assistance or supervision with injector install...Andrew has been kind enough to bring me some new injectors to the GTG that he had balanced and setup via expert DBW. He has also graciously offered to loan me his tool to remove the old injectors. He said he could help me but will likely be busy doing tunes. In preparation for this, I've cleaned the engine, blew it dry with compressed air, particularly around the glow plugs (for future ease) and the same around the injectors. Afterwards, spraying those areas with penetrating oil, letting it sit, then blowing off (and out) with compressed air again. hopefully, this will minimize any dirt/grit around those areas. I hope to bring all the tools to do the job (although I can't recall if I have a crows foot as big as 17MM). I have not done the job before, if someone could assist or supervise, it would be much appreciated. If there is a charge, please let me know so I can plan accordingly. I will be bringing some "drinks". Since this is a complete injector swap without removing the nozzles, I'm thinking with the experts around, it should be easy. I'm staying with friends Friday evening in Greenville and plan to arrive at Dan's "prior to 8 AM" to let things cool down appropriately. (Dan, if I get there before 8 am, I'll just wait in car, nap or whatever)....but if there is something you need help with, I can help.
Let me know if anyone is available.
I'm also bringing intake gasket/cleaning set, bolts, brake clean, mapp gas torch, etc, everything to do an intake cleaning job on same car IF it can be fit in the schedule. Again, I can do the work, but haven't done this job before. If someone can supervise/assist. This is my first GTG and I like to do and learn as much as I can. I'm considering hosting one in N. Ga. in the Fall.
Thanks, G
