Fix_Until_Broke
Thanks Rub87 - We've tried moving the timing around at low RPM, but I was not able to tell much of a difference between the tunes since there was such a difference in the turbos. Not saying that it's not there, but I wasn't able to see the difference on such a different setup than I'm used to.
I'd like to dyno it, however that will be a while. I wanted to work on it over christmas and get the actuator fixed and work on the tuning a bit, but it's not looking like that will happen with family plans and such. It's perfectly driveable now so should only get better once I get everything dialed in.
After driving it for a few weeks now, I can tell that it will definitely be hard on tires
. The limited slip is working more than it used to, particularly with my snow tires. It feels a bit like driving a semi with a 15 speed - accelerate, shift, accelerate, shift, accelerate shift, accelerate shift and now you're doing 40 MPH
. Handy thing is that it does not really matter if you're in 3rd, 4th or 5th gear - if you want to accelerate, just lean on the throttle and away you go.
