ground wire from body to top of clutch/tranny
Status
Not open for further replies.
Seatman
Scotland
2014 Skoda rapid elegance 1.6 cr tdi
See now, this is a thread for legalising some drugs, don't see many stoned people arguing, just getting confused and going off on one lol
40X40
Experienced
Kansas City area, MO
2013 Passat SEL Premium
Butmechanics these days don't care about school only if you know how to work. Anyways I'm done here I brought up a point from another person all you nice people can chim in instead you set me off on my way. No more posts here bye bye
Buttmechanic = Proctology = The perfect profession for someone whose OCD manifests as obsessive hand washing. Yes, you have to go to school for it.... :D
Bill
TDI_
North Jersey
1998 Jetta TDI_
But..... the party just started :(
8
8v-of-fury
Guest
... I joined too late. :( I missed it all.
I don't think I have ever heard of static energy issues inside of coolant, if this were true.. could we harness this back in to the battery someway? Do away with the alternator maybe??
JarheadBoom
PA
'96 Passat TDI
Boy did this take an abrupt left turn...
when the motor is spinning, you creat a static discharge which gets let out into the coolant hence the reason why coolant is NEVER a lifetime fill. The static discharge let off by the engine has to go somewhere hence the ground wire I stated connects the motor/tranny to the chassis/unibody of the car. Now if you modify your car to rev faster then before, a larger wire maybe 0 gauge vs 4 gauge is what I have been told is required/recommended. That's why I ask if you guys know anything about this or why my licensed transmission guy/mechanic mentioned this to me. I also stated that the connection look a little corroded so a good start would be to clean up the connections for a better ground contact :confused:
To put it very simply and bluntly, you've had smoke blown up your ass by someone who saw you as either:
A- a potential source of a laugh for the day;
B- a source of additional income, for work that isn't necessary; or
C- a target for abuse.
I'm an FAA-licensed Airframe & Powerplant mechanic. I've been working on helicopters since 1993, both military and civilian. Helicopters are well-known generators of static electricity, due to the nature of their rotor systems moving through the air at high speeds. While I was in the Marine Corps, I worked and flew on the CH-53E Super Stallion, which has been documented to generate over 25,000 volts of static electricity through it's 79ft diameter, 7-bladed main rotor system.
Look closely at the following picture. That stainless steel wire, touching the ground, between the two tires? That's where that 25kV+ of static electricity goes to ground on the CH-53E helicopter. Note how small it is (1/8" diameter, to be precise)...
- Your TDI WILL NEVER generate as much static electricity as a full-scale helicopter of ANY size.
- You don't need a bigger grounding cable between your engine and body because of static electricity.
- You may need a new grounding cable due to corrosion issues.
TDIDaveNH
Left Lane Coal Roller at Large
North Conway, NH
1997 Passat TDI x2 1984 Buick Century 4.3 diesel. 2012 X5d 2012 Passat 6-speed
This is why this forum is so great, you get folks from all walks of life that have all manner of specialized training/experience, high levels of education and most importantly: real answers. win-win!
TDIPWR33
Canada
1999 TDI MK3
Ok I get it 100% thanks for the input from a real professional. The guy said what he said and misguided me into thinking something is up. Maybe it was a myth he herd about w.e thanks guys sorry for getting so defensive, all I wanted was some good inputs and not what ended up happening. :)
8
8v-of-fury
Guest
Ok w.e.
Like, can you maybe like, talk to the guy and get a confirmation so that we can like, get closure or w.e?
SmokeFree
Easton, PA
2011 Golf TDI, 2008 Audi A3 2.0T, 2010 Mercedes Sprinter 3500
Dude, stop wasting your time trying to get one over on a whole forum. I don't agree with the way you were jumped on in the first page but the following pages don make me feel bad for you. Just let it be it's just a forum, and everyone is being honest and just having fun with you now. Upgrade your ground wire and report back to us.
TDIPWR33
Canada
1999 TDI MK3
the thread is still up, where are the moderators and admins that should have closed this thread a long time ago?
TDIDaveNH
North Conway, NH
I believe they may be waiting silently in the wings for you to hear back from Prestone and post up their response to you inquiry.
TomJD
St. Louis
2000 Jetta TDI GLS, 2015 Golf TDI
Hopefully JarheadBoom was given a proper thank you. He single-handedly owned this thread.
TDIPWR33
Canada
1999 TDI MK3
It was a good explanation that's for sure. I did mention above that I thank him for a real professional opinion. It was good.
TDIPWR33
Canada
1999 TDI MK3
If I knew where this ground wire was I would inspect it at least. As for if the static discharge effects the coolant I haven't asked. I am sure if there is a ground wire, the static will go through the wire to the ground and not transfer through the coolant. Thanks for other inputs here that cleared things up, I think seatman mentioned in the old days due to the fabric of clothes people has a wire from their seats to the ground to dissipate electricity.
Status
