Grinding when accelerating?
ecala001
California
03 golf
I just got my 5 speed swap done with a bew tranny on my 03 golf alh.
I seem to get a metal rubbing noise when accelerating fast. when I accelerate slow I dont hear the noise.
would this be a bad cv joint possibly? gears are fine when going to the others.
-I had recently changed my clutch and throwout bearing
-added new gear oil
muzy
Southern Alberta
02 jetta TDI
Is the engine moving under hard acceleration?
You can see this with hood open and ebreke engaged, just load the engine, don't fully engage clutch .
If so look at all engine and transmission mount locations for broken,loose or missing componates.
Cheers
ecala001
California
03 golf
Cheers
I just found out I got a rip on the driver side boot. will this make the sound?
BobnOH
not-a-mechanic
central Ohio
New Beetle 2003 manual
Not the rip itself, but if all the grease flies out the joint will quickly deteriorate. Sometimes you can just regrease and fix the boot, often the whole joint is shot.
JETaah
mi 48836
What did you use for clutch and flywheel? All new stuff?
ecala001
California
03 golf
I have a south bend stage 2 clutch and flywheel. I replaced clutch friction disk and throwout bearing. Reused the flywheel and pressure plate from donor car which was replaced 20k miles ago
