graphing MAP and MAF.
runonbeer
Maintenance EnthusiastVendor
Austin, TX/Chapel Hill, NC
'00 Golf 02M, '10 Golf 02E, '02 UTE 02M
Yo,
I'm a computer dummy, therefore, I can't seem to figure out how to turn the data logs into coherent graphs.
Other problems: No ecxell on laptop, dead (dying) battery.
I've logged MAF per the FAQ and then saved the log file to a disk in order to open it in excell and see a graph. no graph.
All It showed was a spread sheet with scatterd info and from what I recall it seemed to indicate that the engine wasn't even running
So, can someone please explain to me how to successfully graph info. aquired from vag-com.
I have a copy of exell to install and I'll be getting a dc adapter for the computer.
I need to graph my MAf and my MAP.
Thanks.
Fred, thanks for the OBD section!
jaydhall
Aurora Colorado
2012 Passat SE, 1999 NB, 1999.5 Jetta GLS, 2004 Jetta
I believe Eric Mauer(sp?) has posted this. I know this might not help you but here goes. Open Excel. Open the file you have created. (Log file.) Use the chart wizard to make a graph. (Use the help function in Excel.)
If you play with it a while, I am sure you will get results. Once you get excel, we can talk more.
KERMA
here
currently 99 beetle and 2011 335d
First you select the data to graph. The hit the "F11" key and Excel will automatically generate a graph. This is the quickest way to do it, but sometimes Excel guesses wrong about how you want the graph to look.
Yes. Uwe has the right answer.
twojettas
MN
99.5 Jetta, Atlantic Blue; 85 Jetta TD, Dark Red
If a few of you guys want to send me a few sample logs and a few sample graphs that you generated from the logs, I will build a program that will automatically generate the Excel graphs for you.
Brandon
