Got my Malone Stage 3 done!
KERMA
here
currently 99 beetle and 2011 335d
Just don't take pictures that show your VIN or license plate, otherwise KERMA might get upset.
Contraire, I'll be the one laughing and saying "I told you so" :rolleyes:
jsf350
new ipswich nh
13 jetta tdi
whats mpg?
im banging out 46+ on winter fuel and 20-30* temps and snow tires... and i dont drive easy
stg 2 with cr 170 turbo
pkhoury
That guy with the goats
Mountain Home, TX
2013 JSW, 2 x 2002 Golf, 1995 F450 7.3L
whats mpg?
Lucky you - my average is 36-40 overall now. Then again, I'm also at Stage 3.
turbobrick240
maine
This a thread about Malone stage 3 tunes for cr tdi. If you don't like that- don't post here.
pkhoury
Mountain Home, TX
So now we're holding the tuners responsible really ??? What about personal accountability huh ?
Tuners, no. But Kerma seems to have a real smart@ss attitude. I'm amazed he even sells tunes and then spits in the faces of those who have a tune.
So what you're saying, is that those who use drugs should be held accountable, but not drug dealers, right?
+100. It couldn't be better said.
pkhoury
Mountain Home, TX
On another note - is 0-60 an accurate measure compared to quarter miles? Used the stopwatch feature in PolarFIS a month or so ago. Got 0-60 in S mode in 7.9, and manually shifting, 8.5. I forgot if that was before or after I upgraded to the 3.5.
jason_
michigan
2015 s wagon dsg
I'd say no. Wheels are harder to turn in higher gear...
Sent from my s-off'ed m7 with CM11
Mrrogers1
Omaha NEEEBRASKA
2011 Golf TDI 6MT, 2011 Jetta TDI DSG, 2015 Golf Sportwagen S TDI DSG, 2010 JSW TDI 6MT
I was wondering if you still have your car and how it (namely the tranny) I holding up after all these years and I'm sure, often spirited drives. I have a buddy with and off-road TDI (Buzzken + Malone stage 2 and DSG tune) that is thinking about doing one of the Hybrid CR140 from XMan, CP3 and Malone stage 3 (upgrade from stage 2).
I wanted to make sure he's not asking for trouble with the DSG and stage 3 as I thought it was better suited for higher torque and tunes.
MIVWTDI
NY
12 JSW DSG (RIP), 15 GSW
The car was bought back by VW in 2017. I had about 70k of punishing miles on it. I had the DSG flash done early on. I had no major issues with the DSG or anything else. Just curious why you wouldn't run a cr170 or hybrid cr170? I would definitely put in a S3 IC. If not you might have trouble with your EGR's. GL
Mrrogers1
Omaha NEEEBRASKA
Thanks for the response! Going this route https://www.xmanturbos.com/product-page/2-0tdi-cr140-cjaa-cbea-cbab-bv43-52mm-billet-wheel-hybrid as it's said to bring in boost earlier and better than the CR170 and give a bit wider power band. I will mention the IC to him and will ask about EGT max ranges to keep eyes one. I don't think he has anything to monitor but I will recommend at min, a Scangauge II.
pkhoury
Mountain Home, TX
I sold my 2010 in January. Only problems I had were that the DSG sometimes had problems going into reverse. Usually turning the car off and back on again would fix it, and I'd get a code in VCDS mentioning the transmission mechatronics.
Mine also had a CP3, S3 intercooler, and the CR170. Actually, that's what my 2013 has on it (moved over from the 2010), but that's different, since I just had to put on a beefier dual mass flywheel/clutch that I got from darkside.
Keep in mind that I sold the car with just barely under 251K, and also did a lot of heavy towing with the same car (heavy towing being 2-3K, with the highest at 4800 to bring home a pallet of cement, when the truck took a $#it).
