Amen.DrewD said:Why is this even a topic to debate.
GMARK said:SUNRG,
In looking at the difference in the calcium numbers between Pentosin 505.01 and Delvac, remember the purpose of Ca as part of the oil's composition (a detergent).
See link: http://www.bobistheoilguy.com/basic_lubrication_design.htm
I find that simply looking at the total values of an oil's LAP to be rather short-sided. As you have posted before, IIRC, Elf 506.01 has the highest LAP of approved oils for the PD, and it stands-up very well against Delvac 1. Even superior in some respects.
Analysis of friction modifiers (phosphorous), and anti-wear/extreme pressure additives (zinc) also shows favorable numbers for Elf 506.01, but that's getting off-topic*. The real difference to me as far as 505.01 goes, is that being Group III, they are less thermally stable and some have shown an unexpected tendency toward oxidation because of their long-chain/short-chain molecular composition. I believe any PAO/Ester basestock to be superior to hydrocracked conventional oils, regardless of additive packages used in the GIII oils. Do I think Delvac is superior? Yes. It has a robust additive package, and what I consider to be a much better basestock.
Regarding the Amsoil AFL:
Remember that Amsoil refuses to submit their products for official certification, but will claim that they meet or exceed manufacturer's specifications. I do believe they make a good product, but in re-formulating AFL from HDD to LDD, aren't you really saying that the oil was effectively "dumbed down" for use in the PD?![]()
I'm willing to bet (obviously), that I'm correct in my choice of Delvac 1. After all, it is being used successfully unit-injector type in engines costing more than my Jetta. If I'm wrong, I'll post it here for all to know and see. Everyone can learn from what I'm doing, whether you agree with it, or think I'm a total idiot for trying.![]()
Respectfully agreeing to disagree,![]()
GMARK
*Let's save our 506.01 discussion for another time.[/quote}
I asked about the change in Amsoil and was assured that it's still PAO base stock. I received a case last week, and will try it next oil change. Cost $5.99 a quart shipped.![]()
Its like eating high cholesterol foods or using tobacco, the results will be seen a long time after ingesting them and it will be too late then.d2305 said:I asked about the change in Amsoil and was assured that it's still PAO base stock. I received a case last week, and will try it next oil change. Cost $5.99 a quart shipped.![]()
If I'm going to pay for a synthetic oil, I want to get a synthetic oil. All of the 505.01 oils are blends. I may destroy my engine, but I think not. The real tests comes when I (with adult supervision) change the Timing Belt.nortones2 said:What makes you think the Amsoil 505.01 doppelganger is a PAO oil?
Andy said that it's PAO base stock. Some of the other Amsoil products are group III base stocks HDD or something like that.nortones2 said:fair enough, but are you sure the Amsoil is a synth? I read the blurb they put out, and it sems to be a semi-synth, because they are not trumpeting 100% synthetic. May be mistaken, but thats my reading...
I haven't kept up with the thread because there was too much useless flaming, but have you had a peek under the valve cover to see what it looked like?GMARK said:3k Delvac 1 sample tapped and sent off to the lab. I'll post the UOA later next week.
G
The upper intake manifold looks like it might interfere with the removal of the valve cover. You may end up pulling the upper intake off to get the valve cover off for inspection.....Reggie said:I haven't kept up with the thread because there was too much useless flaming, but have you had a peek under the valve cover to see what it looked like?
Thanks for offering your engine for the sake of gathering data!
No. No, no, no, no, no.Zero10 said:1) He's not doing it to save money, he's doing it to prove that the 505.01 spec is BS
You tie in 505.01 with ACEA A3/B3. 505.01 is VW specific spec not an ACEA spec. From what I have read on here, no one other than VW knows what the exact details are of 505.01. Correct me if I am wrong.Carefully compare the test sequences for ACEA A3/B3 (gasoline/LDD/ 505.01), and ACEA E6/E7 (HDD).
GMARK has always maintained this is his choice.they want to sue and claim it wasnt their fault!
sudden failures from non 50501 oil
If that was meant for me, im not afraid you might be correct at all, i hope you are for the sake of your wallet.GMARK said:Judging from some of the vitriol in these posts, it almost seems as if some of you are actually afraid that I just might be correct in my thinking. Why get wrapped around the axle over this?
Using that analogy, except modified for root beer, to make it work better (because I can make a point using it)...Reflex130 said:Its a bit like having coke on your cornflakes instead of milk?
My 01 PD130 is a taxi, there are three others on the firm, all had done 100k miles on 505.01, now two of them are using 'another good quality TD oil' , 20-40k since then, all ok so far.bhtooefr said:a TRUE test of 505.01 vs. Delvac would best be done in a fleet environment, but that's going to be difficult to do.
