GotEuroCorrado
- Joined
- Nov 14, 2004
- Location
- just out of north east philadelphia
- TDI
- 2015 Porsche Cayenne diesel, 2005 Audi allroad 6spd, 2007 WCM ultralite (super 7)
so ive got 64k 5ps 2001 Golf Tdi GLS RC Euro 3 + Kerma PP520 + 11mm pump + k&n filter + cat + mufflerectomy Sachs stage 2 clutch with stage 3 pressure plate + g-60 flywheel +vr6 brakes + BBS RXII wheels + H&R Race springs + Bilstine shocks.
this car has never given me good fuel econ. most i seen highway is like 44 when car was stock, now i get bout 37-39... city its gets down to 32 when flogghing. i am constantly watching the way i drive to make smooth shifts and no dump the pedal.
ive done the following
~cleaned manifold
~advanced timing (just below top line in tdi timing graph)
~adjusted iq (bout 6)
~streight pipe exhuast (thought cat may be clogged)
~pp520 injector nozzels (though oem were bad)
~always 8oz of powerservice per fillup
~keep tires inflated to 40lb and run 16" wheels
~switched injection pump to 11mm from 10mm thinking pump may be bad, but i still get way low fuel econd even with 11mm pump.
~new trans fluid
~90% of fuel is from highway
~k&n filter
~no snow screen
~replaced brake lines
~fresh fuel filter
~fresh coolant temp sensor
car gives no codes, pulls real nice, turbo boosts 18or so lb. it does not eat oil. starts up on first crank as well, even in the dead of cold. neevr gave me any problems... except this one. it does smoke a bit more then it should. even before the 11mm pump.
i have a vnt 17 sittin in the garage and i really wana put it on but if i cant get this car to give me at least high 30's in the city i am going to take mods off and sell.
to give u guys an example. i just broke 1/2 tank and it was only 320miles... I AM VENTED!!!!!! about 100 of those miles are higway.
also i still have all my engine and underside covers.
~cleaned manifold
~new trans fluid
~k&n filter
~no snow screen
~fresh fuel filter
