Gone Golfing
JonA
Rhode Island
2002 Golf TDI M/T
Really enjoyed reading through spifflifkin's (and others') threads about work they're doing on their cars and wanted to throw mine into the mix. Won't be as fun or cool as an engine with a thrown rod, but whatever. Here I go.
Bought a 2002 VW Golf TDI M/T ALH with a mildly rough interior, but appears to be no rust on it, ~234,000mi for $4,000. PO brought it from Seattle to RI, and decided to sell it before hitting the second timing belt interval. Perfect timing for me, ever since I got rid of my second mk4 Jetta, I've been regretting it. So here I am with an opportunity to baby the car I've wanted for the past oh, 10 years or so. Everything in the engine bay seems to be running just fine, so my plan is to get the interior looking pretty, then begin building up some HP.
First order of business was timing belt, had it done by at BMB Motorworks. Beside getting close to the TB interval, it was like 10yrs old... I was very on edge for the short drive from purchase to home, and then home to the shop.
After that was done, enjoyed getting around to a couple people's boneyards to pick out little bits and pieces, switches, trim here and there, etc... But I'm thinking I'll change out the interior. It's the duotone which I like, but it's so much harder to find matching color parts for, and I have at least one door card that I don't have the skill to bring back to life. Have a line on a complete black interior with (I think) leather heated / memory seats, which I'd like. Going to take a look / start pulling it apart Monday. Might also pick an 11mm pump off the donor, if the price is right.
Next order of business, dealing with leaks. The sunroof drains were clogged/disconnected/whatever. First time taking a headliner down myself, and the top clip on the pillars is a bear... I considered not putting them back, but I read they're integral to keeping the pillar trim in place (and not in your face) when the airbag pops. When I put them back, I'm gonna try putting a loop of high-test fishing line on each of them so I can pull them out more easily w/o having to get behind the pillar. We'll see how that goes.
In the meantime, the drain issue was (mainly) due to the right front drain being backed up, and the right rear drain being disconnected from the fitting at the sunroof side. My best guess is with the heat, over time the tubing shrunk and was no longer watertight in the fitting. Tried putting some RTV on the tube and sticking the fitting back on, but didn't really hold. Not looking to do this again anytime soon, so put some JB Weld SuperWeld Extreme in there and that seemed to do the trick. Did them all while I have the headliner down, and priced getting the headliner reupholstered. Local shops are all about the same at $400 (though I didn't ask whether it'd be any cheaper with it out of the car, will see when I take it to them).
After I get all the stuff for the interior Monday, I have a line on a complete interior wiring harness for heated seats + steering wheel controls for $50, as long as I pull it myself (which I prefer anyway). Will probably grab that next so I can get all the interior swapped out over a weekend or something like that. Looking forward to taking everything apart and putting it back together with care. So far the few things I've pulled apart (glovebox, visors, etc) have been over-tightened to the point that the screw holes through the pieces have almost all been broken off. Seems like the PO's mechanic or someone just went around using an airgun to tighten interior screws and breaking off mount points all over the place. Oh well.
Anyway, so far so great, enjoying the simplicity immensely. Haven't clocked my fuel economy yet, filled up 10gal exactly right when the fuel light went on and currently running it down to that point again but guessing it'll be around the lower end of 40-45mpg range. Driving mostly pretty conservatively but occasionally dropping the pedal to the floorboard. Looking forward to doing some upgrades to build power buuut it's gonna be a while since my budget is trashed, plus I've gotta get rid of the extra cars.
Will post some pics later, it's rainy out right now.
updates
8/8/24
Adding to the list... I recently discovered the style of brake caliper that the pads slide in and out without having to remove the caliper on the Touareg, thinking I might want to swap a set of those in for ease of changing in the future if there's a bolt on option... 8/14/24 addendum: found these guys that look pretty reasonable.
8/10/24
Adding to the list again, will do the heater core and blend doors when I replace the cabin wiring harness, get em out of the way while it's apart. Also, maybe some dynamat?
8/13/24
Uh oh... just found out park distance sensors (rear only), folding mirrors, self levelling headlights, MFD, and probably more can be retrofitted... yep, I'm browsing Kufatec. Going to add to the long term list, in the end, after getting it looking and running the way I want, I'd love to just fool around adding option after option and end up with a ridiculously optioned Golf.
8/19/24
I'm probably not going to keep updating this little part of the list because it'd get crazy long. I've updated the to-do list with new stuff I'd like to do almost every other day and reorganized the order about 1.5x a week ha.
to-dos
engine
  • timing belt (@234k mi)
  • intercooler to EGR valve boost tube replacement
  • driver side axle
interior
  • front door cards
  • passenger GTI seat
  • trunk release switch
  • glove box
  • left side marker
  • sunroof drains
  • euro switch
  • head unit, turned out I had idiotically switched the main module and the steering wheel control module on the XSVI-9003-NAV wiring harness adapter I'm using. Switching them back resolved my earlier issue that seemed power related.
  • 11mm pump
  • .260 nozzles
  • brake fluid for a flush
  • belly pan
  • heater core
  • seats (black fabric)
  • rear door cards (black leather)
  • steering wheel controls
  • relay/control module
engine
  • rubber fuel lines that attach to the hard lines around the fuel filter, 1J0130307R and 1J0130307T. crazy expensive from any parts seller except Cascade German, they're $169.95 and $99.98 respectively from CG.
interior
  • blend door
  • cabin wiring harness
  • instrument cluster lighting blinks here and there... tested grounds in the engine bay and they're all great, but wondering if swapping the wiring harness will help? maybe the wrong amperage alternator got put in? not sure at this point, and doesn't seem like too big a deal yet, but it's on my mind.
exterior
  • rear beam axle front bushings - White line Poly per Zak99b5's rec
  • waxoyl powershield cavity wax in rockers, panels, etc.
  • waxoyl hardwax undercar maybe?
  • coilovers? cup kit? something better than what's on there 'cause it rides so hard. might actually want a little lift though for the nasty speed bumps they have in Providence. found a nice set of Open Road Technologies coilovers for about half the original price on a donor car I'm thinking I'll go with...
engine
interior
  • fancy seat covers
  • rig an LED strip for trunk lighting
  • 3DColorMFD? ColorMFA? myself? by Litke?
  • dynamat?
  • carpet/trim swap maybe?
  • if replace carpet, might do some hardwax underneath the carpet... paranoid about rust since my first couple cars rockers went. Really want to take good care of this thing.
exterior
  • defenders, RT 45s, or winter tires
  • caliper paint. silly I know, but I think yellow calipers would be a great accent on the dark blue. not a huge fan of the blue all by itself, but yellow accents would make it look great to me.
  • paint fix up?
  • brakes + rotors, rotors are warped and it's annoying feeling. I like brakes that bite quickly and smoothly.
interior
engine
  • arp head studs
  • 3 bar map sensor
  • some front mounted intercooler
  • some turbo
  • some performance camshaft
  • some better clutch
  • euro crash bar
  • tuning
exterior
options
engine
running tally
$4,000 - golf
$750 - 11mm IP + .260 nozzles
$647.67 - timing belt labor
$353.58 - timing belt kit
$200 - windshield replacement
$200 - black leather door cards
$120.49 - post purchase inspection
$100 - GTI front passenger seat
$100 - multifunction steering wheel
$91.38 - various upper intercooler piping replacement parts
$54.97 - timing belt hardware kit (mounting bolts etc)
$50 - front left axle
$40? - glove box
$40? - floor mats
$40 - black cargo cover
$30 - euro switch
$30 - front tweeters, front speakers, front window gaskets
$27.81 - wiper puller tool
$20 - side marker, trunk switch, center console front trim, misc...
$20 - dewalt screw driver
$18 - JB Weld (classic)
$18 - pop off engine cover bits
$13 - another #452 relay (first never arrived)
$16.04 - trim puller tools
$10.99 - drill to 1/2in adapter
$10 - GOLF letters + antenna adapter
$10 - oxy acetylene torch
$10? - various nylon bolts/nuts/washers
$7.48 - rice grain bulb (wrong size)
$5.43 - #452 relay
$5 - belly pan
$2 - old VW manuals
car: $4,000.00
tools: $86.84
labor: $768.16
parts: $2,363.40
total: $7,218.40
8/10/24
Couple pics of current condition of the interior:
JonA
Rhode Island
2002 Golf TDI M/T
Feeling pretty good about how much I got done so far this weekend:
  • yesterday, bought a spare set of "GOLF" letters. Thinking of trying to install some tiny neodymium magnets in them so I can rearrange the letters to say "GOOF" when necessary.
  • today, bought a euro switch from one fella on Facebook for $30, and then a set of Recaro (the OE black ones) from another fella on FB for $100.
After a long stretch of spraying down, scrubbing, skinning, etc... here's my temple to the arrogance of man (after about two hours of seat cleaning/biocide)(feat. headliner et. al languishing in the corner):
When I pulled the seat covers off a couple seats, I found out why they were probably the price that they were, looks like some mildew...
Doesn't look too bad, but looks can be deceiving. I think what I'll do is wash the seat covers with some biocidal laundry detergent, then throw the cushions in the trunk of the Golf and hit it all with a chlorine dioxide bomb like this. There's probably mildew in the current car seats anyway, right? It couldn't have endured 234k miles of butt sweat and not gotten any mildew.... yea, that's what I'll tell myself. Anyway, here's some removal pics and notes. Probably known already, but there are these little tabs that the fabric is jammed into underneath the headrests, so gently pulling up and trying not to get the fabric caught on the tabs (and subsequently snapping them off) is gonna be the way to go:
Then removal took me a minute to figure out, you flip the headset all the way "down" or "forward," however you see it, then the foam will give birth to the inner headrest bit:
Removal is easy from there. The seat part had these little cross bars which I did not expect but were pretty easy to deal with as well, but for anyone interested:
Neat design. While I was about all this, I figured I'd do some soft touch removal on all my trim pieces, since I've removed 80% of them anyway. Read somewhere on TDI Club that TSP was the way to go, but TSP isn't really a thing at the hardware store anymore, something to do with regulated chemicals or other... there is TSP substitute though. That's literally what they call it, TSP substitute. Anyway, read it was decent and seemed ok on ABS plastic. Guess we'll see, but boy was it good for removing the soft touch. Dumped a small container bit in a big ol' bin, got about a half inch of coverage and just let piece rest in there one at a time for about 5 mins each, took em out and they were clean. Gave them a little bit of a scrub here and there, but for the most part, it was the easiest removal I've done... BUT! The plastic don't look so great now. Not terrible, just not great. Maybe I'll throw something on top of it, but eh... do I care that much? especially the dash ends, the main thing I care about is not having sticky icky hands every time I have to go in the fusebox or whatever. Here's what it looks like:
Black spots are where it's still wet. It mostly kind of greyed a bit, still black (the lighting probably makes it look greyer than it is), but uneven and slightly whitened. You can see some spottiness, and you can also see "through," the three darker spots/lines on the left of the dash caps are where there's plastic molding on the back. Gonna have to stop kidding myself, I do care and I will try to find a good permanent plastic paint for this stuff. If anyone has any recommendations I'm open. Would like to match colors... Currently soaking the beige formed parts, had to dilute with a bunch of water to get it over the top, but will leave soaking overnight and see how it goes:
That's about it for today, should be picking up a set of four decent door cards with black leather inserts tomorrow morning. Excited as I love the leather inserts, but wish I could find a set of duotone ones that were in decent shape / for a decent price... maybe down the line sometime. Currently, the driver side door card insert is flopping about because the melted over tabs that hold it have been broken off by the years baking I suppose. Add to that more upholstery coming apart a la headliner, numerous missing clips and screw holes, and I figured I'd rather just replace.
STDOUBT
Portland, effing Oregon
dos jettas
Love the restoration ethic. It should be more widespread imo.
I have always used 99% isopropyl alcohol to remove that soft touch. Seems kind to the ABS.
I don't know TSP, but I have seen some people use WD40 to bring back "sunburned" plastic
that has the same whitened, dry look. Maybe try a test spot. Kinda scrub it in, then let it dry away,
maybe overnight, then wipe clean.
JonA
Rhode Island
2002 Golf TDI M/T
Appreciate the WD40 tip, will definitely give it a go! Haven't finished all the soft touch removal either so will probably make use of some isopropyl alcohol as well.
  • Like
Reactions: Ton
PakProtector
AnnArbor, MI
Mk.4's and the Cummins
I think those are VW high bolster seats. Very nice IMO, and the foam they're built with lasts much better than the stuff Recaro used.
Your steering wheel could use some attention I think. My preference is Mk5 or 6 flat-bottom GTI which happen to be covered in leather... :) The harness mods to keep airbag function is well documented by a few folks who did it early and went to the trouble of sharing it wid the rest of us.
Douglas
JonA
Rhode Island
2002 Golf TDI M/T
Ooh, neat! Wasn't very familiar with these seats but looked nice enough and the price was right. I think I saw a site at some point that had replacement parts for these but I can no longer locate it. If I'm feeling intrepid tomorrow I'll begin pulling the covers off the front seats, and once I do I'll have to see if I can just replace that bolster or augment it, then maybe some upholstery shop can repair the hole while the cover is off. Doubtful that I pull the covers off the back seats back rests at this point, as I'd rather not reglue the backing... but maybe, we'll see.
Steering wheel was going to be tomorrow's project... we'll see whether I follow through or not as I just a half hour ago lost a crown... but the plan was to pull a Mk4 steering wheel with controls (also blessedly covered in leather), clock spring, steering wheel control module, and wiring harness out of a donor and install it in mine. I like the idea of the Mk5/6 wheels, but I'm gonna keep it more or less OE for the time being.
Today was a great haul though, and a great day until the crown thing. Oh well, guess it all comes out in the wash, today I picked up:
  • $200 - set of black leather door cards, looking pretty good overall, from a really nice guy off FB.
  • $40 - great condition black cargo cover from a great guy, also off FB. Cover even has both little strings in good working order. Had a blast talking cars etc... with the guy for an hour and a half or so.
  • ~$50 - front left axle, same guy, he had it and I need one so I figured I'd snag it from him while I was there. Just something to tide me over as mine has a cracked boot.
  • $5 - belly pan, same guy.
  • $10 - oxy acetylene torch from a random tag sale
  • $10 - dewalt screw driver, same tag sale
  • $2 - couple ooooold VW manuals, will share some pics later but they were neat
Some pics of the haul:
Door cards look great. Belly pan is decent, not that it's strictly necessary but... just trying to get everything as close to 100% OE as possible (though not color matching necessarily, at this point), then will start making modifications from there.
Sadly, the inserts' plastic welds have broken off as they do BUT! they otherwise look pretty great. This'll be the area where I'm gonna start improvising. I'm going to take off my old door cards and do some various test fixes on those inserts before going live with the nice doors. I'm going to pop all the plastic rivets, and then install some latches / studs / some type of mechanism that makes it easy to get the inserts on and off, but keeps them secure while they're on, aaaand I want to make it work without drilling so the outside of the door looks fresh. This way in case of re-upholstering, it'll be easy enough to pop in and out.
On the plus side, everything looks great back here! No broken screw holes, wow! Also, previous owner very neatly packaged all screws and included in little baggies with each door. Lovely.
One thing that's keeping me engaged in this project is how fun it is finding stuff, and all the people I've bought stuff off of have been such nice people so far. Makes it a fun adventure where I get to meet new people along the way, while also hunting deals... pretty addictive. If you reading this were any one of the good folks I linked up with, thanks!
That's it for tonight. Hoping the dentist will get me in bright and early so I can go on my merry way and pull apart someone else's car for a couple hours...
JonA
Rhode Island
2002 Golf TDI M/T
Isn't that pretty?
No, I didn't do the whole wiring harness yet, so I've got no horn, no steering wheel controls, but damn if it isn't a sight for sore eyes. Looking forward to getting it working. Curiously, the clock spring was already the 5 pin one. I haven't pulled the reinforcement plate to take a look at the relays in my car... but something isn't adding up... this steering wheel came from the donor car the next picture is taken from, can you spot what's missing?
Thaaaat's right, it's the 5/6 slot relay, 451! So was pulling all this for naught?
I managed to pull up an awful lot today. I was just short of finishing this before I started working my way to the front and noticed it missing. Oh well, should've checked that first. It was fun though, and hopefully good enough practice to R&R the harness on my car without unnecessarily breaking things. I did forget about the crossmember bolt underneath the cowl so I wrestled with that for a while before realizing the folly of my ways.
When I got back home, slapped the new steering wheel in and accidentally popped the little plug that goes to the airbag:
But that's what a pinout tool is for, right? I pulled the two pins for that connector from the clockspring clip and popped them into mine. If you happen to do such a thing, here's how to fix. Pop the cover off the clock spring clip (pic 1 below), then stick anything in between the tab that keeps the pin in place and the body of the clip, and pull gently on the wire (pic 2 below). Repeat on both wires, then repeat on the messed up wiring clip. Slip the new wires into the old clip and you're set. In the second pic below, the tab on the pin is circled in red, and the direction to push it is the little red arrow.
Well.. I like this wheel so much, I'll probably go without the horn until I can figure out whether I'm going to find a donor car, or just run wires for the MFSW and heated seats. Was hoping to do this OEM, but maybe that was a bit of a pipe dream. No crown fix until Wednesday, so going to grumpy about all this until then at least.
JonA
Rhode Island
2002 Golf TDI M/T
First 10gal of diesel got me 452.3 miles, or 45.2mpg. Not bad. Kept boost pretty low generally, but floored it probably no more than half a dozen times in that stretch. Some city, some longer trips, pretty regular mix of driving for me.
  • Like
Reactions: Ton
JonA
Rhode Island
2002 Golf TDI M/T
Added a cost breakdown... whoops... didn't realize I'm already nearly $2k in and haven't actually gotten much done yet 😓
JonA
Rhode Island
2002 Golf TDI M/T
Bit of a daunting figure for me since I've never bought a car for more than $3.5k before this... but I wouldn't mind that being the bottom line, I'm just going to have to slow my pace down a bit haha. Gotta remind myself that I should be able to keep playing around with this thing for the next 10-20 years if all goes well.
BobnOH
not-a-mechanic
central Ohio
New Beetle 2003 manual
Yea, that's a nice car with all the issues cleaned up. Should take you to 4 or 5 thousand miles. The no rust bit is huge.
JonA
Rhode Island
2002 Golf TDI M/T
Pulled apart one of the front seats this evening. Will I regret it? Probably. Not looking forward to getting all the springs hooked back up. Had to take a peek at the Bentley just to get the bottom cover off... shameful. Interestingly, there are heating elements in the bottom wings, as well as the back. I'm pretty sure my 2005.5, 2010, and 2014 Jettas only had it in the butt area. Looks like there are some marks where the elements melted through and burned the foam a little.
Some more clip removal. The wires inside the upholstery of the backrest were a pain to get out, both in the front (below) and back (next row of pics).
The back of the backrest. Not terribly remarkable, but there was this little elastic strap that just hooked on one of the wires on both sides. Haven't seen anything like that and I guess I was just surprised there wasn't some three part locking clip involved or something. Had to undo all the springs so that I could work with the wire backing to unhook the front side of the backrest... it has a wire that comes through on both sides at the top and hooks into the wire backing pictured below.
Didn't realize the heating elements would be sewed into the seats. No longer sure of my plan to just throw them in the washing machine. Maybe it'll be fine? I guess I've most likely gotta get the driver side off for repair anyway so not a total waste of effort. Sewing isn't something I'm handy with so will most likely take it wherever I get the headliner done and see if they can do it all in one go. Also will see if I can find some foam to fill in the broken chunk.
After all this, yea, I'm probably going to put seat covers over these.
  • Like
Reactions: Ton
wonneber
Monroe, NY, USA
I recovered the seats in my old 72 (or so) Fiat Spider.
Wasn't a hard job.
Had to buy a crimping tool for the clamps that held the covers in place.
I let the covers heat in the summer sun while I took the seats out one at a time.
Went very well.
The convertible roof was a bit more challenging to do with glue to hold it to the bars.
Used the car for three summers (iIrc)
Then the car burnt in a big garage fire. :cry:
Eight garages went up.
Made the front page of the local newspaper.
JonA
Rhode Island
2002 Golf TDI M/T
Geez, sorry to hear that... hope you at least got a newspaper clipping out of it.
spifflifkin
WA
2002 Golf
This is an awesome thread! I'm looking forward to seeing more of your progress!
JonA
Rhode Island
2002 Golf TDI M/T
Hey, it's you! The inspiration for this thread! I've re-read your thread a few times and yet I still never remember how to spell your name haha, I finally bookmarked/watched it yesterday so I wouldn't have to search every time. Really enjoy following along!
Popped in this morning just to drop this here... someone listed a set of the red rear seats on Facebook for $50. Sure would be neat if it were the full set! I'm not going to get 'em, but thought it was remarkable. I'm going to have to block Facebook marketplace on my computer before long because I'm on a shopping spree here.
Priced out the headliner repair, local shop said $225 with it out of the car. The driver seat repair, $275 for bolster and the rip. Not too bad. Might be a week or two before my budget can sustain it, still trying to sell off these other cars. Am I going to need to do a DPF or something to the '14 to sell it? I hope not. But as soon as I sell it, I'll be able to get a lot more done on this project.
spifflifkin
WA
2002 Golf
Awesome! You motivated me to start working on my interior again. The door cards are all shot. I got one from a junkyard but it was nasty! I finished cleaning it today. The covers I got are a cloth. I'll try to put one on next week.
I got my headliner recovered for about $200 (if I remember correctly) at a local place. They didn't wrap the cloth around in all the locations that it should be. One side of the sunroof is cut flush with the hole. You might want to label the wrap areas so you're covered if they mess up.
I might have them re-do the driver seat. All the other seats are fine.
Keep up the good work!
JonA
Rhode Island
2002 Golf TDI M/T
Alriiiight, did much less fiddling around this weekend, chilled out a bit. I am running some trials with my bespoke door card insert fastener solution, or BDCIFS for short. Edit: credit where it's due, I knew I had read this idea somewhere and found snadam's thread where I originally got (stole) the idea. Yesterday, I removed one of the old door cards for testing, cut off the plastic welds (I think a dremel would be better for this, but I lent mine out and should retrieve it before doing other doors). popped out the insert (the foam backed fabric was disgusting), and laid down some Loctite Plastics Bonding System. Didn't work very well. Almost immediately popped off when I tried to screw the insert down to the door card today.
Glued down nylon bolt:
So it's back to JB Super Weld Extreme or whatever it is. Will see how that holds up tomorrow. In the mean time, took a few exterior pics after cleaning up the headlights. Found a Turtle Wax Headlight Restoration kit in the closet and it took me like 10mins to clear these up. Can't imagine it'll last long, but looks good for now.
Clear coat is pretty much wasted, front fenders and bumper cover aren't totally lined up, rear quarter panel has a bit of a ding to it, crack in the right rear light, scratches and chips everywhere... but I still love it though. Picked up some nice chairs sitting on the side of the road Saturday, and a free futon frame today. Wished for GTI (or is it GLI?) flip down seats when I was picking up the futon, but hey, I still fit it all in easier than I would have a Jetta. Good times.
JonA
Rhode Island
2002 Golf TDI M/T
If I never see foam-backed fabric again, it'll be too soon. I finally finished removing all seat covers and threw them in the wash, which was the WRONG MOVE. They're not destroyed but the foam-backed fabric that I didn't realize the covers were composed of started falling apart. Ugh. On top of that, the discoloration is still there on the back seats, and I ran them through the wash twice. My best guess is the thin layer of foam underneath the upholstery is to promote a little circulation of air, so as to prevent swamp ass, as I believe it's referred to. I'm sure I can find some replacement foam-like material that doesn't degrade, or disgust, while maintaining some level of breathability.
So, pro tip for all those who follow, don't bother taking your seats apart to clean them, do the best you can with the covering in place, and save yourself all the time and frustration that I didn't... that said, if for some reason you do end up taking your seats apart, the main tip I've got for the front seats is use a clamp to scrunch this part together, it'll make it easier to remove the retaining bars:
I didn't anticipate spending this much time on the minutiae of the interior, and I'm not enjoying it very much. I thought I'd blitz it out of the way and get on to the fun power and handling stuff, able to enjoy a clean, complete interior. Well, forecasts have been revised, targets adjusted, and with a heavy heart I continue on.
Did actually finish something this weekend, small though it may be. I took the top trim off one of my rear door cards, in prep to swap it with the new door card (originally from a Jetta, the top trim is a couple inches longer). In total, took me probably an hour to remove. The plastic welds are a pain to remove.
I also finished putting the pop cover hardware together that I bought off @Ajlal24 (thanks!). Few minutes with a Dremel tool and a cutting disk and we're good to go. Just make sure not to breathe too much smoke. Luckily for me, I just picked up smoking recently so I'm safe.
spifflifkin
WA
2002 Golf
How is the BDCIFS coming along? That's a pretty interesting idea. Have you seen the Zip Tie Method?
I bought some cheap cloth door card covers that don't really fit well so I probably won't use those. I can't decide what other ones to buy. Whenever I start looking for some I fall down the indecision rabbit hole...
I was thinking of taking the seat cover off like you did, but I think I'll skip that now! :LOL:
JonA
Rhode Island
2002 Golf TDI M/T
Glad I could save you a bit of trouble!
The BDCIFS concept is pretty good, but the single stage glues are not cutting it. JB Super Weld Extreme held decently, but I'd like it to be better. I've been roughing each of my tests up after they've cured and nothing has withstood as much as I'd like yet.
@snadam (whose thread I believe I originally stole the idea from) PM'd me the type of plastic epoxy he used. I've yet to buy some, but likely that'll be next.
I haven't seen the zip tie method... Might actually change course and give that a shot... As I've recently learned with the seats, the most time consuming way is not always the best.
JonA
Rhode Island
2002 Golf TDI M/T
THAT is a great idea. All I'd need is an S off a Sportwagen and a Y off a... Caddy (EU)? Voyage (Latin America)? Playa (South Africa)? Tayron (China)? Didn't know any of those were a thing. No models with a Y in the name sold in the US as far as I can tell though.
Currently feels more like FML though. Was driving back from VT yesterday, and as I came over the last big mountain I start to notice the turbo spinning higher and higher... but not getting that much more power... then seeing black smoke... no lights, no codes logged. Managed to make it home by keeping boost as low as possible and hugging the breakdown lane up most hills (sorry if you got stuck behind me). I haven't done a lot of learning about boost yet so all I can do is guess at the issue. "Grateful" for this "opportunity" to learn. Going to start by testing vacuum, starting with N75 using the steps outlined in this thread.
May be a few days though. I've focused my energy into trying to get the PCV off the Touareg at the moment since I don't feel like dealing with this right now.
STDOUBT
dos jettas
Jon, hold up on those door cards until you've seen these.
Two great ideas for door card insert repair:
JonA
Rhode Island
2002 Golf TDI M/T
That looks much easier and cheaper than what I've been planning to do. Love that, it'll leave more room in my budget to do stuff that's really fun.
I think I'll go with the zip ties over the band clamps since I think most of the tabs are still serviceable on my new(er) door cards, but the band clamps idea is great if they're totally gone. Thanks STDOUBT & spifflifkin!
JonA
Rhode Island
2002 Golf TDI M/T
Alrighty, time to deal with my turbo issue. Tomorrow, I'll test the N75, actuator rod length, vacuum, etc. following burpod's guide. Will also probably try to pull off the cold air intake (if that's the easier one? haven't bothered to get smart about boost yet since nothing's ever gone wrong for me in the past) and poke at the turbine. Have been poking around for a cheap, local VNT15 or 17 in case the turbo's blown, though I desperately want to buy burpod's GTD2060VZ... I need a reliable, registered, inspected car now and have 0 in my fleet. Fun stuff later. GTD2060VZ, if you can hear me, I'll come back for you.
